zenke
Posted: Sun Aug 14, 2016 5:05 am Post subject:
El Capitan OSX Is it OK for G2 ? |
Hi
I have had a look around this list but I dont see any discussion regarding the use of G2 on the newest OSX, El Capitan.
Are people using this and manageing to still run the 1.62 G2 editor. I would be very interested to know.
Thanks
jamie |
tomhall
Posted: Mon Aug 15, 2016 11:11 am Post subject:
| runs perfectly fine |
zenke
Posted: Tue Aug 16, 2016 10:29 am Post subject:
| Thank you very much. Good to hear |
rick
Joined: Jan 31, 2005 Posts: 6 Location: Amsterdam, NL
Posted: Sun Oct 16, 2016 3:58 pm Post subject:
Re: El Capitan OSX Is it OK for G2 ? |
| zenke wrote: | Hi
Yes, runs fine still on 10.11.6. I even tried the beta of Sierra, and the editor still runs on that too.
On OS X 10 the open dialog, to load patches, still works okay, but not as refined as with newer OS X applications for some reason. E.g. the directory last used is not remembered. (Just add a shortcut in the Finder windows left column.)
rick jansen
PS: hi all, it's been a LOOONG time. I see I last visited here in January 2005.. |
Joined: Apr 03, 2004 Posts: 24506 Location: The Netherlands, Enschede
Posted: Sun Oct 16, 2016 4:02 pm Post subject:
Hi Rick, thanks for the report :-) _________________ Jan
zenke
Posted: Sat Oct 22, 2016 3:42 pm Post subject:
Hi all
I am having problems with using the G2 editor on el capitain. I can see that others are OK with it. I can open the editor but i get a ' major error' message and it will not conect to the aynth.
Do you have any suggestions? |
rick
Posted: Sun Oct 23, 2016 1:40 am Post subject:
| zenke wrote: | Hi all
I get that message when the editor loses the USB connection, like when unplugging the USB cable. Is your USB connection ok?
rick |
zenke
Posted: Sun Oct 23, 2016 2:05 am Post subject:
Hi
I tested my USB connection. Thanks for thta suggestions Rick.
However i have discovered that it is to do with 'allow apps downloaded from ..' which is in preferences, security and privacy.
If set to anywhere all is fine. Great!
Thanks jamie |
zenke
Posted: Sun Oct 23, 2016 4:49 am Post subject:
| Well, i spoke to soon. I can get it to connect, but it frequently disconnectes and requires reopening and reconnecting of usb. |
rick
Posted: Sun Oct 23, 2016 7:04 am Post subject:
| zenke wrote: | | Well, i spoke to soon. I can get it to connect, but it frequently disconnectes and requires reopening and reconnecting of usb. |
See if there is anything in the console log?
Is the NM plugged directly into your mac''s usb, or through a hub or so?
Try another usb cable too.
rick |
zenke
Posted: Mon Oct 24, 2016 6:48 am Post subject:
Hi
Yes I have it plugged directly into computer.
I dont really know how to use Console. I looked at it but I donet see anything which seems related to the Nord software.
ny idea what I am ;looking for ?
jamie |
zenke
Posted: Mon Oct 24, 2016 8:46 am Post subject:
Any ideas what this means ?? this what i found in console after opening G2 editor.
24/10/2016 16:37:36.000 kernel[0]: 006356.151223 Nord Modular G2@1a150000: AppleUSBDevice::ResetDevice: <software>
24/10/2016 16:37:41.567 Nord Modular G2 Editor[658]: ATS: Invalid FontObjectID (3) - only low 16 bits are being passed in.
jamie |
rick
Posted: Tue Oct 25, 2016 12:35 am Post subject:
| zenke wrote: | Any ideas what this means ?? this what i found in console after opening G2 editor.
That last msg is in my console log too.
Just be sure your USB connection is okay. If you have a lot of USB devices try to disconnect some?
rick |
zenke
Posted: Tue Oct 25, 2016 5:30 am Post subject:
I tried every USB connector on my computer.
On omne it works after a fashion. It works after I have plugged it in. Then after that if I close the editor and reopen, it does not connect to the G2. |
rick
Posted: Tue Oct 25, 2016 12:43 pm Post subject:
| zenke wrote: | I tried every USB connector on my computer.
Don't close the editor then
What happens if you pull the usb plug an reinsert? |
zenke
Posted: Wed Oct 26, 2016 8:54 am Post subject:
Yep, Thats what I decided.
If I unplug and replug it seems to reconect. But thats a pain as the USBs are at the back of my machine which is under my table. |
rick
Posted: Wed Oct 26, 2016 9:43 am Post subject:
| zenke wrote: | Yep, Thats what I decided.
Then unplug/replug at the back of the NM..?
Or get a usb extension cord and use that. |
zenke
Posted: Thu Oct 27, 2016 3:55 am Post subject:
Ahhh! Sometimes it just needs someone elses mind on things!! Duhh!
Extention lead I shall try. Thanks Ric.
Yep That seems to work . Nice one! I can live with that.
cheers
j |
