Yamaha A3000 sampler Floppy drive replace
Page 1 of 1 [3 Posts]
Gothboy
PostPosted: Sat Nov 16, 2024 1:39 pm    Post subject: Yamaha A3000 sampler Floppy drive replace Reply with quote  Mark this post and the followings unread
I was considering getting this as a replacement: https://www.amazon.com/GoTEK-SFR1M44-U100-Emulator-Industrial-Embroidery/dp/B0762NCHC6/ref=asc_df_B0762NCHC6?mcid=1c44b137ddfb3084a84ab79a01f6b157&tag=hyprod-20&linkCode=df0&hvadid=693535620612&hvpos=&hvnetw=g&hvrand=15581086412802231085&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1016202&hvtargid=pla-570573645288&th=1
A GoTEK SFR1M44-U100 3.5 Inch 1.44MB USB SSD Floppy Drive Emulator Grey it's 34 PIN but will that fit into the sampler?
Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
"We are the music makers and we are the dreamers of dreams"
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
Audio files: 158
PostPosted: Tue Nov 19, 2024 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Smile
I had a similar situation last year when i wanted to SD card my A3000 v2 sampler , i bought a floppy emulator then realised my mistake, 1.44mb at a time was not appealing , what i really needed was to replace my 2.1Gb internal 10000rpm scsi hard disk drive inside that i had fitted in 2001 which was starting to sound like a 747 passenger plane taking off on runway.
Early this year i ordered a ZuluSCSI RP2040 , which using your own pcb mount pillars can be fitted inside the A3000, the zulu board allows me to have it set up as a virtual rack of HDD's , i kept the SD cards capacity a lowish one 16Gb and i have 6-virtual HDD's at 2Gb each, and each drive is partitioned into 8 partitions after formatting them using the sampler it's self, (set up to suit my studio).
I done a lot of searching for set up info and i gleaned enough info from gearspace.com to get me running.
Gothboy
PostPosted: Tue Nov 19, 2024 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The HD inside the A3000 is working but the Floppy drive will not light up when inserting a floppy disk..so it will not load a sample. That's why I would like to install the GoTech USB emulator replacement in the bay. I have done a bit of research and it appears the 34-PIN spec should work and I have seen that AKAI owners have used them for those samplers so I thought I's ask here if anyone else used them just to clarify.
That said I also have an external Yamaha CRW4416SX SCSI CD rom drive that I used to load larger samples and it turns on and works but the A3000 will not ....for some reason that I can't figure out...load samples...which is really super annoying.I thought getting the emulator would be a quicker way of fixing things because right now the only way of getting anything is to record samples straight in.
16 GB Ram
10.11.6/El Capitan
