Where to set the breakpoint?
Page 1 of 1 [4 Posts]
organischa
PostPosted: Sat Feb 23, 2008 9:31 am    Post subject: Where to set the breakpoint? Reply with quote  Mark this post and the followings unread
Hi all Modulars! Very Happy
At the moment i make my first experience in synthesis on the G2. Now i try to unscramble and realize the information of robs tutorial in my brain and synth. The first breakpoint is the breakpoint, where is it reasonable to set if i try to get stable formants. When im using e.g. A Phrygian over 2 octaves?
Is there written informaion outside wich i overlook?
Jens
Falk
G2 patch files: 29
PostPosted: Mon Feb 25, 2008 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello organischa.
I am afraid I don't understand what you are asking about.
There are only 2 modules that I know of that has breakpoints in them, the Operator oscillator and the LevScaler. Perhaps that helps?
If not, maybe you can rephrase your question?
Regards
/Falk
organischa
PostPosted: Fri Feb 29, 2008 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow is my english so bad that you are scared of it? Embarassed
In general i need more Information about the leverscaler an how to use it in the right way to get FM/ZeroFm waveshapeing.
Where is the right point to set the Breakpoint of the Levelscaler?
Jens
Falk
G2 patch files: 29
PostPosted: Mon Mar 03, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi organischa.
Not my area of expertise. Most of what I now about FM is from this document SY Programming which is about the Yamaha SY77/SY99.
I hope you can find something in there.
Regards
/Falk
