DBop II - a simple programmable Drummachine...
Page 1 of 1 [12 Posts]
PostPosted: Fri Jun 29, 2007 5:40 am    Post subject: DBop II - a simple programmable Drummachine...
Subject description: ... or a cute little toy?
hi all,
thanks to dave kendall i was able to upload the original site of tom g's DBop II drummachine. i did not build it yet (i probably never will, who knows) but here is the info for all who are interested.
i will add some better schematics and the 16-step mod soon...
http://www.modular.fonik.de/files/EFMforum/DBopII/title.html
some links will be dead for this only a copied version of the faded original site...
LukeDI
PostPosted: Fri Jun 29, 2007 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems like a neat project and cute too, to bad I've already got a big list of projects to work on.
goodrevdoc
PostPosted: Fri Jun 29, 2007 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, i've had this for awhile. It one of my favorite things that ive never built. Spent some time breadboarding the individual drum sounds, they are not bad. It would be worth it to build, IMHO, if it were to be adapted to a 16 or dare i say it, 32 step sequencer. all it would take is some extra DIP switches and some more CMOS. I got into it breifly but got sidetracked...
-justin
23isgood
PostPosted: Sat Jun 30, 2007 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Does it sound like an 808? Thats what it says in the docs, but does it really sound like one. Are there any audio samples anywhere?
Check out my music
zipzap
PostPosted: Sat Jun 30, 2007 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
i like trhe sequencer. Don´t get what the and gates after the 4017 are for, though.
Maybe i´ll build one, but i might not use typical drum sounds. If you already have a nice drumbox with sequencer (i´m just planing one), this thing could be added to add some effect sounds and noise patterns.
And an idea i really like: it could be gated not by it´s own clock, but by the master sequencer.
Use it like an individual sound module with a programmable pattern.
For that i would include a reset after step button, so the patterns can be 2-8 steps long.
Or, even more cool and complicated:
I always use a rather fast master clock that is dividet down to drive my sequencers.
Any devision of that fast clock could be anded with the gate from the main drum sequencer.
then this little unit would play rolls and little bursts, or small pattern fragments - all programmed by the dip switches.
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
PostPosted: Mon Jul 02, 2007 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
just added the 16-step mod:
http://www.modular.fonik.de/Page37.html
(scroll to bottom of site)
widdly
PostPosted: Tue Jul 03, 2007 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
From the page "the clock also gates the 4081 AND gates making sure the output goes off before turning on again". So it gives you triggers at the length of the clock pulse. If you left them out and had two steps on in a row you would only get one long step out.
zipzap
PostPosted: Tue Jul 03, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i see. Well, thre is a way that is simpler, in my oppinion. I used it with my 4017 sequencer. Just an resistor and a cab to ground on every step. Turns the high signal into a short pulse.
PostPosted: Tue Jul 03, 2007 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
what do you mean by "simpler"? one would have more solder joints. Wink
zipzap
PostPosted: Tue Jul 03, 2007 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
that´s true. Embarassed
I remember why i did this: because of lots of different clock dividers and aswing controll of the clock i didn´t manage to get the anding of clock and 4017 right. Like the gate coming with the next step and stuff like that.
No problem with this design.
widdly
PostPosted: Tue Jul 03, 2007 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would think that the correct cap value would depend on the clock speed.
You could clock it with the blacet midi sync chip and a divider to have midi synced beats.
http://www.blacet.com/MSdata.html
zipzap
PostPosted: Wed Jul 04, 2007 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
that´s perfect, of course.
I used rather narrow pulses so there is no problem with high clock speeds. The pulses are used to trigger variable gatelength generators (retrigerable).
