seraph
Editor
Audio files: 33
Posted: Sat Mar 29, 2008 2:29 am Post subject:
Deep Sleep Subject description: An hibernation Dashboard widget |
Deep Sleep is a simple Dashboard widget which allows users to put their computer into hibernation mode, also sometimes called software suspend mode. This widget only works on a limited number of Apple computer models.
http://deepsleep.free.fr/ _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Posted: Sat Mar 29, 2008 6:01 pm Post subject:
Err....why?
what's wrong with the existing sleep button??  _________________ ACHTUNG!
seraph
Editor
Audio files: 33
Posted: Sun Mar 30, 2008 1:30 am Post subject:
| v-un-v wrote: | Err....why?
what's wrong with the existing sleep button??  |
there are 5 different sleep modes on recent Macs accessible from Terminal or thru this widget. I chose the widget
| Quote: | 7. Description and modification of the different hibernate modes
When the computer goes into sleeping mode, its behavior depends on a power manage-
ment variable called hibernate mode. The hibernate mode can be set to different values:
• 0 (quick): Default sleep behavior on most Apple computers. RAM is still powered on while
sleeping. Wake up is fast. Safe sleep is disabled.
• 1 (deep): Hibernation behavior. System is totally shut down while sleeping. RAM contents
are dumped to disk. Wake up is slow.
• 3 (safe): Default behavior on Powerbook HD and later computers. RAM is still powered
on while sleeping. Wake up is fast. Safe sleep is enabled, so RAM contents are
also dumped to disk before going to sleep.
• 5 (deep): Same as mode 1 for systems with encrypted virtual memory.
• 7 (safe): Same as mode 3 for systems with encrypted virtual memory.
