ioflow - multifunctional protocol router for open hardware
PostPosted: Wed Oct 15, 2008 12:14 pm    Post subject: ioflow - multifunctional protocol router for open hardware
Subject description: Project at the monome forum
This seems to be aimed at something wider that just monomes, so I thought I'd post it here if someone's interested.
http://post.monome.org/?CategoryID=9
Two quotes from the start of the first thread:
Everyone who has been following the discussion on “open source perceptions” (http://post.monome.org/comments.php?DiscussionID=2025) might have seen that there are several ideas about developing an open source protocol router that can be used in conjunction with projects made by the rapidly evolving Open Source Hardware community.
"Starting from there, we can start to find common points and factorize protocols. We can also start to define mapping techniques from serial to OSC. Following step is to write the associated libs in various languages. Ideally we should be able to map from anything to anything: e.g. midi note to keyboard strokes, or serial to midi, or OSC to key stroke. Maybe this is not needed initially. I would propose to focus on serial to OSC and see if we can extend the system later on, if the project goes well."
