today> Cancelled due to equipment failure - Sorry Chez Mosc
Pocketprotectors ?
Page 1 of 1 [11 Posts]
PostPosted: Wed Aug 20, 2003 5:30 pm    Post subject: Pocketprotectors ? Reply with quote  Mark this post and the followings unread
http://www.dct-net.co.jp/special/usb_hot.html
PostPosted: Wed Aug 20, 2003 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 29, 2003 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
What is that?
a USB toothbrush to brush your teeth in front of a computer?
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 29, 2003 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
and the other one must be a USB coffee cup. the computer is going to tell you when the coffee gets to the previously programmed temperature.
I guess it works also with teacups.
Am I right?
PostPosted: Fri Aug 29, 2003 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
The heater is meant for keeping the coffee or whatever hot - brew the cofee, fill the cup.. plug it in.. turn the switch and the USB will power a heating unit in cup.. so the brew will stay hot.
Great idea.. but my big problem is that I drink the coffee pretty fast.. the espresso goes down like.. ker-ploff.. What I really need is a Bialetti pot which is powered by heat from the hard disk arrays .
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 29, 2003 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
If I were you I would immediately patent this idea!
the problem could be how to build the CONVEYOR BELT to move the heat to the coffee machine Shocked
PostPosted: Fri Aug 29, 2003 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
HMMM.. there must be a way to do this.. macs should come with a plate on top for the Bialetti pots.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 29, 2003 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
you are nuts Very Happy Very Happy
btw did you know the G5, as optional, has a nuts toaster Shocked Rolling Eyes Very Happy Very Happy
PostPosted: Fri Aug 29, 2003 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Whatever gave you the impression that I would like to toast my nuts? Laughing Cool
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 29, 2003 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
GET OUT!!!!!!!!
PostPosted: Fri Aug 29, 2003 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Wink
