Nord Lead 2x - PitchBend Error startup - possible to fix?
Page 1 of 1 [4 Posts]
pushwithlegs
PostPosted: Thu Feb 19, 2009 11:42 pm    Post subject: Nord Lead 2x - PitchBend Error startup - possible to fix? Reply with quote  Mark this post and the followings unread
got the unfortunate "pitch bend error" on startup and was wondering if anybody had opening their nord up themselves to remedy the problem.
the strange thing is that intermittedly the pitchbend still works and also the function of pitchbend will work when i use the nord as a slave to another synth...
There's no place near me to send the synth in so i'd love to be able to fix this myself!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 20, 2009 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
For opening the synth see:
http://electro-music.com/forum/topic-29716.html
Check the connector to the motherboard.
Wout
hedia
PostPosted: Thu May 07, 2009 4:21 pm    Post subject: pitch bend error Reply with quote  Mark this post and the followings unread
Wout
I have the same problem with my nord lead 2x, what should i look for on the connector to the motherboard? (i havent opened my synth yet)
thank you!
-hedia
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu May 07, 2009 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome hedia
Best to check all flat cables inside by disconnecting - connecting them.
Also check the little connector on the PitchStick device, special the wires coming from the ModWheel.
Please, disconnect the power cable first!
Wout
