FS: Nearly complete MFOS ULTIMATE EXPANDER and MFM/patch
druish
PostPosted: Sat May 29, 2010 11:36 am    Post subject: FS: Nearly complete MFOS ULTIMATE EXPANDER and MFM/patch Reply with quote  Mark this post and the followings unread
For sale I have a nearly done ultimate expander. It just needs to be wired to the panel and about 6 shielded wires need to be soldered to the PCB and wired. I also have a MFOS Multi function module that is nearly done. All it needs is for the LEDS to be soldered to the PCB and wired to the panel. The panel is a custom FPE panel with an additional patch section to convert 1/4inch to banana jacks and banana to 1/4. The FPE panel was $85 and is a hair less than 8.75in tall and 7.25in wide. it was intended to be used with the expander and ultimate. The MFM will come with the LEDS and all Pots needed to complete the project. due to time constraints and larger projects I am forced to sell these for less than cost, plus all the major work has been done.
If you have any questions please PM me.
Expander: $225 plus shipping
MFM: $100 plus shipping
 Filesize:  400.91 KB
 Viewed:  143 Time(s)
 Filesize:  355.83 KB
 Viewed:  142 Time(s)
 Filesize:  347.65 KB
 Viewed:  146 Time(s)
 Filesize:  452.67 KB
 Viewed:  141 Time(s)
 Filesize:  319.6 KB
 Viewed:  149 Time(s)
