 Forum index » Clavia Nord Modular » G2 Performances - Completed
ElNino
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Dec 16, 2010 3:01 pm    Post subject: ElNino
Subject description: droney prf
Start of the school holidays and the rain settles in. Uncomfortably warm too.
This very low bpm prf features a patch (only slightly modified) from Chet's PM tutorial in slot C.
The Slot A Drone uses a pair of sine oscillators with the first 5 harmonics generated by multipliers etc. The fundamental and each harmonic is AM'ed and shaped through a Sat module.
Slot B has a new <=12.5% piano. Which means you could get 8 voices on a single slot (with no effects). It uses sine multipliers again. FM piano needs 1:1, 3:1 and 5:1 ratios (at least). This one has a good mid tone which has been quite elusive for me in the past.
ElNino.prf2
Droney
 Filename:  ElNino.prf2
 Filesize:  16.85 KB
 Downloaded:  2118 Time(s)
