Buchla 200 original panel size
Page 1 of 1 [13 Posts]
frenchyinmunich
PostPosted: Tue Mar 16, 2010 2:22 pm    Post subject: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
Hello,
I m looking fir the original and precise size of the Buchla panels.
High and large... In mm and inch
Someone here knows?
Best regards,
F
cbm
PostPosted: Tue Mar 16, 2010 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm using this as the starting point for my modules:
ModulePanelDimensions.pdf
 Filename:  ModulePanelDimensions.pdf
 Filesize:  33.15 KB
 Downloaded:  2270 Time(s)
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
zthee
PostPosted: Tue Mar 16, 2010 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
frenchyinmunich
PostPosted: Wed Mar 17, 2010 3:05 am    Post subject: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
Hello,
Thanks a lot for your answer.
Why do you call it eardrill?
Also, do you know the thickness?
I already used for a sequencer a material which is called Alunox.
Which kind of material Buchla used?
Best regards,
F
TekniK
PostPosted: Wed Mar 17, 2010 5:59 am    Post subject: Re: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
frenchyinmunich wrote:
Hello,
Best regards,
F
http://www.eardrill.com/modules/
Fine HQ handcraft buchla format modulles
TekniK
PostPosted: Wed Mar 17, 2010 6:06 am    Post subject: Re: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
Hello,
Best regards,
F
They use Yttrium-aluminium i think.
frenchyinmunich
PostPosted: Wed Mar 17, 2010 6:40 am    Post subject: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
Thanks Teknik!
Well, I didn't know neigther heard anythink about eardrill before that post...
Interesting.
Concerning this Ydrium Material, I really don't know the equivalent name in Europe/France/Germany.
Someone knows it?
It would be the best to find the same material.
Thanks a gain,
F
TekniK
PostPosted: Wed Mar 17, 2010 8:35 am    Post subject: Re: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
Thanks Teknik!
Interesting.
Someone knows it?
Thanks a gain,
F
hey, thats was a joke, Yttrium is extreme rare,and sometimes they mix it with alluminium to get a strong but lightweight alluminium. Very Happy
Any alluminium will work, i think trying to have the same brushing is the most importand if u want your panel looks like the original.
They have an epaisseur of 1,5mm
frenchyinmunich
PostPosted: Wed Mar 17, 2010 9:04 am    Post subject: Buchla 200 original panel size Reply with quote  Mark this post and the followings unread
I already used Alunox in the past, for the midibox sequencer.
see the link following:
http://midibox.org/forums/forums.html?showtopic=8725
The surface is quite fragile to my taste... If a srew driver fall down on the surface, you get a scratch... Embarassed
By the way, I juste tuned again the sequencer yesterday. With VFD displays and the case is again consolidated...
I add soon some video on youtube of it driving some old stuff.
All the best,
f
cbm
PostPosted: Wed Mar 17, 2010 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
My panels are .062" Aluminum, I think it's a 6061 alloy. Vertical grain brush finish. It would be good to get a sample of a Buchla panel to give your machine shop for grain matching. And before anyone asks, the Pantone color for the blue is 2935.
TekniK, thanks for posting the link.
Chris Muir
The Bad Producer
PostPosted: Wed Mar 17, 2010 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is very interesting! Do you happen to know what the font is CBM?
Thanks for all the info too!
frenchyinmunich
PostPosted: Thu Mar 18, 2010 8:22 am    Post subject: Yttrium Reply with quote  Mark this post and the followings unread
Hello Teknik,
About Yttrium, I think the people in my company use it a lot for the planes or satelite.
you got me Teknik! jackson dancing
f
rubendelacosta
PostPosted: Tue Sep 20, 2011 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to bring this old topic up again...
Anyone knows what font is used on buchla panels?
Regards,
Ruben
