synthesist
Joined: Apr 03, 2004 Posts: 24538 Location: The Netherlands, Enschede
Audio files: 299
Posted: Mon Oct 17, 2011 10:53 am Post subject:
Re: mfos mono mixer Subject description: isnt this one inverting |
| synthesist wrote: | | I must be totally wrong. |
Nope, that's all correct, but since it's an AC coupled (audio) mixer it does not matter too much. For a CV mixer you'd not want an inverted out. _________________ Jan
synthesist
Posted: Mon Oct 17, 2011 11:47 am Post subject:
thanks for the answer. I think I want to build this one next.
But just for my comprehension:
there is no positive AC flowing into my speaker-amp. It is reversed now?
the speaker-amp is feeding the mixer-circuit with pos. AC and gets back the "ground" from the mix. circuit?
This works?
I`d really like to learn more about electronics, but I have to wait till next year when a class starts. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Mon Oct 17, 2011 2:31 pm Post subject:
The AC signal is ideally centered around 0 volts
if there are no gains through the mixer
when the input signal is at say +5 volts the output
signal will be -5 volts and vice versa
the output signal is the same as the input just 180 degress out of phase
to it, overall the signal is still centered around 0 volts and over time the AC
signal can be considered to be neither positive or negative
The statement a positive AC signal would imply there is a positive DC offset to the AC signal which would be inverted to a negative offset at the output. this can occur but is in audio terms not desirable as in the case of an amplifier driving a speaker any DC offset component in the signal will
have a detrimental effect on the speakers coil, at a high enough level this will effectively turn the speaker coil in to a heater which they dont like being at all this is why audio mixers should be AC coupled so that any DC
component is effectively blocked , a CV mixer on the other hand will allow both DC and AC signals through as there is no blocking capacitor involved and in this case it is generally preferable not to have an inverted output.
hope this helps _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
