Transistor Matcher P-N-P Layout (+ etched PCBs for sale)
Page 1 of 1 [6 Posts]
roman_f
PostPosted: Sat Feb 04, 2012 9:18 am    Post subject: Transistor Matcher P-N-P Layout (+ etched PCBs for sale) Reply with quote  Mark this post and the followings unread
Using matched transistor pairs in a single IC is cool, but sometimes not cheap or easy to get them fast, that's why we can use a simple circuit for matching single transistors
I've made my own press-n-peel layout for that, using schematics from minimoog manual (I've found it on dragonfly alley, but guys do not offer the p-n-p solution):
it's very easy to assemble, requires no trimming, works for both PNP and NPN transistors
I've added sockets for transistors and screw terminal blocks for fixing the multimeter leads.
PDF for P-N-P, BOM and schematics is attached
if you can't do PNP by yourself - i can etch the board
price is $20 shipped worldwide, paypal is in@btwn.us
sputnik-tm-pnp.pdf
Press-N-Peel layout
 Filename:  sputnik-tm-pnp.pdf
 Filesize:  383.47 KB
 Downloaded:  618 Time(s)
tm-schem.pdf
Schematics
 Filename:  tm-schem.pdf
 Filesize:  115.44 KB
 Downloaded:  703 Time(s)
sputnik-tm-bom.pdf
BOM
 Filename:  sputnik-tm-bom.pdf
 Filesize:  17.11 KB
 Downloaded:  571 Time(s)
mark_olson
PostPosted: Sat Feb 04, 2012 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool; thanks so much for sharing this!
Mark
PostPosted: Sun Apr 08, 2012 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I breadboarded this circuit and both sides have an oscillation in the BE voltage, so I don't have anything static to measure. It doesn't seem to matter which way I hook the probes.
I haven't had a chance to troubleshoot very far yet, but if this sounds familiar and there's somewhere I should focus, I'd appreciate any pointers.
One thing that confuses me is having nothing but the probe hooked up to the base of the transistor being measured. Is that correct?
frijitz
Audio files: 54
PostPosted: Mon Apr 09, 2012 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's an alternative method:
http://home.comcast.net/~ijfritz/projects/transmat001.pdf
Ian
PostPosted: Thu Apr 12, 2012 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Ian... I've looked at that at some length and have figured that I can use a 4PDT on-off-on (criss cross the power and the diode) and a DPDT (criss cross the emitters) to work up the entire circuit for both NPN & PNP in a small project box, powered by 9V batteries. Possibly overkill Smile but will save a lot of switching around of parts, or a larger circuit board. I plan to use a trimmer too. Should be fun Smile.
PostPosted: Thu Apr 19, 2012 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
So here's what it looks like; not actually wired up on the inside or labelled, but planned in detail, and I wanted to laugh at myself for getting extremely oversized switches Smile
[/img]
 Filesize:  120.95 KB
 Viewed:  306 Time(s)
