flanger/delay with mn3010 schematic??
Page 1 of 1 [7 Posts]
audiomoebe
PostPosted: Mon Sep 10, 2012 3:26 am    Post subject: flanger/delay with mn3010 schematic?? Reply with quote  Mark this post and the followings unread
Dear people,
Because i found a MN3010 chip in my pile of salvaged ic's i like to overlook the possibility to make a flanger myself.
Therefore i am searching for the schematic of the ADA flanger which is originally for the mn3010 i believe.
However, the only schematic i can find on the www is the one that uses the SAD1024.
Is there anyone who will post a readable schematic if there exists one?
Or is it just a pin swap with the MN3010/SAD1024?
Any help is welcome.
Thanks!!
StephenGiles
PostPosted: Mon Sep 10, 2012 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the first
ADA-Flanger-10-189-MN3010BBD-starting-with-pn-227331.pdf
 Filename:  ADA-Flanger-10-189-MN3010BBD-starting-with-pn-227331.pdf
 Filesize:  629.69 KB
 Downloaded:  292 Time(s)
StephenGiles
PostPosted: Mon Sep 10, 2012 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is the second page!
ADA-Flanger-10-189-MN3010BBD-starting-with-pn-227331-page2.pdf
 Filename:  ADA-Flanger-10-189-MN3010BBD-starting-with-pn-227331-page2.pdf
 Filesize:  486.92 KB
 Downloaded:  225 Time(s)
StephenGiles
PostPosted: Mon Sep 10, 2012 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a later version
ADA-Flanger-120-240VAC-operation-page1.pdf
 Filename:  ADA-Flanger-120-240VAC-operation-page1.pdf
 Filesize:  600.46 KB
 Downloaded:  230 Time(s)
StephenGiles
PostPosted: Mon Sep 10, 2012 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
With page 2 of the later version
ADA-Flanger-120-240VAC-operation-page2.pdf
 Filename:  ADA-Flanger-120-240VAC-operation-page2.pdf
 Filesize:  375.21 KB
 Downloaded:  228 Time(s)
StephenGiles
PostPosted: Mon Sep 10, 2012 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
It is certainly not a pin swap, but there may well be a conversion board floating around somewhere.
audiomoebe
PostPosted: Mon Sep 10, 2012 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot!
