Low pass filter
Post new topic   This topic is locked: you cannot edit posts or make replies. Moderators: dnny, v-un-v
Page 1 of 1 [2 Posts]
Joelelectro
PostPosted: Thu Oct 02, 2014 7:33 am    Post subject: Low pass filter
Subject description: Probe a filter with LM13700
I try to make the simulate the circuit and design the example of datasheet Voltage Controlled Low-Pass Filter i take the parameters and formulate for the low pass filter:
fo=(RA*gm)/((R+RA)2*pi*C)
The paramethers are for the:
RA=200ohm
R=100k
C=150pf
IABC=3e-6
The datasheet make reference where gm ≈ 19.2 IABC at 25°C.
and i Supposed:
fo=(200*19.2*3e-6)/((100k+200)*2pi*150pf)
and my result=122.05 hz
In the simulate i take the reference
5 μA ≤ IABC ≤ 500 μA
[img]Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img]
[/img]
My question how i can identificated my filter is corred i use the elements for the desing of the datasheet, only i can see the response.[/quote]
PostPosted: Thu Oct 02, 2014 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Please keep the discussion in one place - I'm going to lock this thread - the same info is at http://electro-music.com/forum/post-403919.html#403919
