Animated Pad
gauthier
PostPosted: Tue Jan 03, 2017 5:36 pm    Post subject: Animated Pad
Subject description: a work in progress pad patch
My first patch for G2, which is still a work in progress, and is quite simple, but I really like the sound I'm getting out of it.
I load it in two separate slots, and play the lowest key on my G2X with hold, and then use second slot to play chords or melodies higher on the keyboard.
What makes the sound interesting to me is the use of the multi filter, the band pass is used with mild delay, while low and highpass are feeding a cross-fader, which is modulated by a synchronized LFO.
Doing sweep with the modwheel gives drastic results on the multi filter.
I've started to assign few controls, but will probably populate more, and focus on the oscillator and envelopes which are currently fixed.
Feedback and ideas welcome.
animated-pad-wip.pch2
Animated Pad Work In Progress
 Filename:  animated-pad-wip.pch2
 Filesize:  2.18 KB
 Downloaded:  3509 Time(s)
