A couple of bugs
Page 1 of 1 [2 Posts]
Wobble
PostPosted: Fri Jan 05, 2018 10:43 am    Post subject: A couple of bugs
Subject description: minor stuff
The SeqPattern works as I envisioned, thank you for making it.
Minor bug; copy E does only seem to work in the first S. In the second S for example, the copy E don't work.
The KleeBit out setting at the bottom 1-3 seems no longer to map to 1-3 output, but 1 to 2, 2 to 3 and 3 to nothing.
The EnvAR at 500 pico seconds don't seem to work. I was loading up a patch I made in a previous version of wren. And its silent until I increase attack to above 500 pico seconds. Attached.
kickBassDrum.wren
Patch that shows problem with EnvAR.
 Filename:  kickBassDrum.wren
 Filesize:  12.28 KB
 Downloaded:  639 Time(s)
PostPosted: Fri Jan 05, 2018 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup - doesn't seem to work right, will look into that.
For your patch I'd have used EnvArRetrig as that one will reliably restart when the envelope did not finish yet at the time a new trigger comes in (and it does not have the issue you pointed out). The non-retriggerable one won't, even when fixed.
