alkopop79
Posted: Sat May 25, 2024 7:53 am Post subject:
Modular synth audio signal buffering Subject description: Do modules need op amp buffers? |
I'm designing a modular synth based on the Sound Semiconductor VCO, VCF and VCA ICs. The datasheet has application circuit schematics for each IC. I wonder, do I need to place op amp buffers on the audio outputs and inputs? Say, does the VCO need output buffering?
https://www.soundsemiconductor.com/ |
Joined: Mar 28, 2006 Posts: 1425 Location: Kansas City, Mo USA
Posted: Sat May 25, 2024 6:14 pm Post subject:
Looks like the buffers are built-in to the chips (though I did not check all of them). Note that the Peak-to-Peak level is 2.5 volts so you will need external parts if you want to change the levels (i.e. 10volt p-to-p).
Are these expensive chips? I didn't see prices for them on the website. _________________ -- Kevin
http://kevinkissinger.com |
Joined: Apr 03, 2004 Posts: 24391 Location: The Netherlands, Enschede
Audio files: 296
Posted: Sun May 26, 2024 6:02 am Post subject:
Wow, I did not expect these chips to be so inexpensive.
Page 21 of the datasheet shows that the output from the VCO chip is from it's internal mixer and does not require an external buffer. If your design uses phone plugs and jacks, I would suggest use of a 1000 ohm resister at every output point to protect the output circuit from contacting ground when plugging in patchcords.
Will look forward to reading your progress on this. _________________ -- Kevin
alkopop79
Posted: Sun May 26, 2024 9:00 am Post subject:
kkissinger wrote: | Looks like the buffers are built-in to the chips (though I did not check all of them). Note that the Peak-to-Peak level is 2.5 volts so you will need external parts if you want to change the levels (i.e. 10volt p-to-p).
Are these expensive chips? I didn't see prices for them on the website. |
Check out the resellers, I think there is at least one in the US.
https://www.soundsemiconductor.com/buy.html |
alkopop79
Posted: Sun May 26, 2024 9:03 am Post subject:
kkissinger wrote: | Wow, I did not expect these chips to be so inexpensive.
Will look forward to reading your progress on this. |
Check out the AN701 note in the Support section of the page. It describes bow to use their quad VCA to build all sorts of historical filters. Fascinating! |
