Pot is making problems
Page 1 of 1 [6 Posts]
R2Music
PostPosted: Mon Aug 28, 2006 2:47 pm    Post subject:  Pot is making problems Reply with quote  Mark this post and the followings unread
Hopefully one of you electrical engineers/circuit bending pros can help me.
I am bending a "Talk and Learn Alphabet" toy that runs from two AA batteries. I have found a couple decent bends but I'm having trouble with my audio ouput. I took the speaker wires and ran a 100k pot in series with the 1/4" jack. Everything is connected and working fine and was working fine before the pot, but my problem is that my output and within the 10 or 15 degrees that I turn the pot it reduces the volume quickly and goes out. Also when I have it at a lower volume the sound is very distorted (that is my biggest problem). Am I using the wrong pot? I also tried a 10K and it acted exactly the same.
If anyone knows the answer you will make my day!!!
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Aug 28, 2006 3:59 pm    Post subject: Re: Pot is making problems Reply with quote  Mark this post and the followings unread
R2Music wrote:
make my day!!!
Cool
bigtex
PostPosted: Mon Aug 28, 2006 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
You probably need a lower value pot. The speaker drive circuitry is designed to drive an 8 ohm load. Now, if you use a really low value pot, you'll end up burning it out because the speaker can probably handle a watt or two, and the pot will probably only be good for a quarter watt. Try a 1k pot or even a 500 ohm pot. You'll probably get better control. Also look for an audio taper pot, because those few degrees where you get most of your control will be expanded on the pot's turning range.
The other thing you could do is get a higher wattage 8 ohm resistor (or just keep the speaker) and use a simple opamp buffer circuit to drive the output. That way the resistor (or speaker) can handle the current of the output amplifier, and the opamp buffer will just read the voltage and send it to your 1/4" jack.
google for "unity gain op amp buffer" or something like that and you'd find a good circuit for that
The only reason I'd recommend removing the speaker in this case is the speaker would act as a microphone and make your recordings less clean. So find an 8 ohm resistor of at least 1 watt power handling (or maybe 10 ohm will be easier to find... you could probably pull one out of an old power supply or something... look for a fatter resistor) and then just use the unity gain op amp buffer. Should work like a charm.
Or just use a lower value pot for a simpler (but likely lower quality) solution.
Good luck!
bigtex
PostPosted: Mon Aug 28, 2006 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://ourworld.compuserve.com/homepages/Bill_Bowden/opamp.htm
Just use the "voltage follower" on this page. Very simple circuit. All you need is to power an op amp and connect the + of the speaker/resistor to the + input of the op amp, and connect the output of the op amp to it's - input and to your 1/4" jack. Very simple circuit.
R2Music
PostPosted: Mon Aug 28, 2006 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will try what you have suggested.
What is the difference between a phono and mono 1/4" jack? Will that change anything?
Also I'm not an electrical engineering buff... can you help explain to me which option would give better audio output? Maybe just tell me to for example: "connect the audio output to resistor type a then to the 1/4 jack".
I need some instructions cuz im so confused
bigtex
PostPosted: Tue Aug 29, 2006 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I figured I should keep the discussion out where others can see. I hope you don't mind. This way, if others have the same questions they might find what result you eventually come up with as the answer they want too! Very Happy
R2Music wrote:
hey thanks for your help with the circuit bending... do you know which type of op amp i should buy? Radioshack op amps
Then I'm not really sure where I should go from there. Any and all help would be appreciated. Thank you
Either the 741 or the TL082 will work. The 741 is a very old design (early 70s I think) and is a single op amp, which is all you need. The TL082 is newer (though still almost as old as me...) with higher quality specs like lower noise and it is a dual op amp. You only need a single channel, though, so I'll leave it up to you which to pick. Or try both. It couldn't hurt to have an extra op amp to experiment with. You should also pick up a breadboard to try stuff out on. First this circuit, and later others.
But you may want to start simpler. I've actually never used an op amp circuit to buffer a speaker output like that, it was just an idea. Here's something that you may want to try that is apparently tested and works:
http://www.epanorama.net/circuits/speaker_to_line.html
Buy a few potentiometer values (like 1k and 5k) and some resistors (like 1k, 5k, and 10k). Start out with a 10k resistor, like in that circuit, and use the 1k potentiometer where the 1k resistor is. Wire it up so the two outside pins of the potentiometer are where the 1k resistor would be (one side connected to the 10k resistor, the other side connected to speaker ground). Wire the middle leg of the potentiometer (the wiper) to your output jack. If that's too quiet, replace the 1k pot with the 5k pot. Experiment a bit with the values of things until you have the ammount of control and the ammount of attenuation (reduction in level) that you want.
So it would look something like this:
speaker (+)
resistor
potentiometer pin
potentiometer pin (wiper) -----> output
potentiometer pin
speaker (-)
