today> Various Artists NYE concert
mono compressor wanted
Page 1 of 1 [3 Posts]
dorremifasol
G2 patch files: 49
PostPosted: Tue Jan 16, 2007 2:10 pm    Post subject: mono compressor wanted
Subject description: a monophonic, cheaper compressor suited for all kinds of signals
It would be nice to have a compressor suited for mono signals.
In my experiments I have found that putting a compressor after a filter makes the sound warmer, at least from my point of.. hearing. The trick is very handy for example after a resonant filter, which usually lowers the output signal. This is one of the things that the G2 can do and no other VA can do, and it's very cool. Unfortunately the compressor is stereophonic, and consumes more resources than it would be necessary to compress a single signal.
So, I wish a simple signal compressor. Probably it could have great uses to other signals besides audio.
I have attached a simple patch, it does not show anything revolutionary but I was working with it before posting this. I find the sound much more interesting with the compressor turned ON.
roundbass.pch2
wish for a mono compressor
 Filename:  roundbass.pch2
 Filesize:  1.5 KB
 Downloaded:  1890 Time(s)
Albert
PostPosted: Wed Jan 17, 2007 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Or at least they could change the cycle load depending on which inputs/outputs are used - this is something that the G2 should be able to do. So if you only use the 'L' input/output-pair, then the cycle load would be less than id you used all both pairs.
/Stefan
dorremifasol
G2 patch files: 49
PostPosted: Wed Jan 17, 2007 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
That would be also nice.
Albert
