<on air> Twyndyllyngs Chez Mosc
How do I bypass a filter?
Page 1 of 1 [5 Posts]
Dr. Spankenstein
PostPosted: Tue Apr 03, 2007 12:05 pm    Post subject: How do I bypass a filter? Reply with quote  Mark this post and the followings unread
How do I bypass a filter? For example...
Code:
SndBuf buf => BPF filter => dac;
I have the sound filtered, but how could I turn off or change the filter for a different type of filter at any point during the code?
Thanks
Rhys
moudi
PostPosted: Tue Apr 03, 2007 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi
every unitgenerator has some basic functionality.
(inherited by the basic ugen class).
the parameter .op(int) controls the behaviour of the ugen:
op(int) (of type int): set/get operation at the UGen. Values:
0 : stop - always output 0
1 : normal operation, add all inputs (default)
2 : normal operation, subtract inputs starting from the earliest connected
3 : normal operation, multiply all inputs
4 : normal operation, divide inputs starting from the earlist connected
-1 : passthru - all inputs to the ugen are summed and passed directly to output
i copy/pasted this directly from the chuck homepage here:
http://chuck.cs.princeton.edu/doc/language/ugen.html
jassas
/moudi
Dr. Spankenstein
PostPosted: Tue Apr 03, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks very much!
....dammit Embarassed
PostPosted: Wed Apr 04, 2007 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't feel too hard, the documentation is scattered a little so things can be hard to find.
As for changing the filter (as opposed to bypassing it), you could set it up like this;
LPF filter2 => dac;
then, any time you'd like to switch you can disconect the buf from the BPF filter by "unchucking" it from there, then connecting it to the LPF.
from memory; the unchuck operator is like this;
SndBuf buf =< BPF filter;
But that one doesn't seem to be on that page.
kijjaz
PostPosted: Wed Apr 04, 2007 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another different idea i have in mind now:
For a smoother switching..
i think an Enveloping would be able to smooth things up.
Code:
// when activated, the fenv route will have gain = 1
// but when bypassed, it'll fade the filtered line down and dry signal up
SndBuf buf => BPF filter => Envelope fenv => dac;
buf => Envelope bypassenv => dac;
// set the fade time
10::ms => fenv.duration => bypassenv.duration;
// codes... etc.
// activate the filter route
fenv.keyOn(); bypassenv.keyOff();
// bypassing
fenv.keyOff(); bypassenv.keyOn();
i hope this implementation can prevent crackle when bypassing
by quite a simple method & some flexibility
(e.g. fade time can be set,
envelope can ramp to any value for a mixing of wet & dry signal,
many more filters can be inserted and mixed with more Envelopes)
