 Forum index » How-tos » Micro Tuning
Microtuning and ChucK
Page 1 of 1 [3 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Apr 10, 2007 4:17 am    Post subject: Microtuning and ChucK Reply with quote  Mark this post and the followings unread
arrow http://electro-music.com/forum/topic-17327.html
udderbot
PostPosted: Sun Jul 15, 2007 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I saw this subject and knew I would eventually get around to having some microtonal ChucK examples.
Basically, this makes an equal-tempered mandolin play slowly drifting moment-of-symmetry-esque rhythms. Play with the initial variables a bit. You might even consider it educationally valuable!
Code:
//rhythm mos explorer
// manifestation 0: equal-tuned mando-handbells
//period (tempo)
.56::second => dur p;
//generator (initial value, fraction of 1)
1. => float g;
//number of notes patterning (also tones per octave)
7 => int e;
//the change to g and/or p each iteration of period
fun void delta()
   0.01 +=> g;
//each boop sporked plays one multiplier (m) of the period...
// only activates notes (no noteOff)
//  queries global variables g and p each time anew
fun void boop( float m, float freq, StkInstrument v)
   //Std.fabs(m)*p => now;
   v => dac;
   freq => v.freq;
   dur begin;
   while ( true )
      if ( m <0> begin;
      } else {
         if ( m == 0 )
         { 0::second => begin; }
         else {
         g*m%1 * p => begin; } }
      begin => now;
      v.noteOn(0.6);
      p - begin => now;
// make a Mandolin with random timbre, chuck to dac
fun StkInstrument mandome()
   Mandolin m;
   Std.rand2f( 0, 1 ) => m.bodySize;
    Std.rand2f( 0, 1 ) => m.pluckPos;
   0.3 => m.stringDamping;
   m => dac;
   return m;
// iterative version.
fun void multispork(int n)
   for(0=>int i; i < n; i++)
  spork ~ boop( i-(n/2), Std.mtof(57.+(12.*i/n)), mandome());
// sequence-of-notes version (make sure size is the same as n!)
[ 57., 59., 61., 57., 59., 57., 53. ]@=> float arr[];
fun void multispork2(int n)
  spork ~ boop( i-(n/2), Std.mtof(arr[i]), mandome());
multispork(e);
while (true)
 delta();
 p => now; }
// a favorite: g-delta = 2/9., eq5
On my music-dedicated 333-Mhz I am limited to 7 notes before garbage synthesis; on my 1 Ghz iMac (running 11 other programs at the same time) it seems able to handle up to 18.
More (and less) at http://scalesmith.blogspot.com
Tell me what you do with it! I plan on doing all sorts of things...
edit: un-mangled by disabling HTML. Thanks Kassen!
PostPosted: Sun Jul 15, 2007 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome, udderbot!
Looks very interesting, could you perhaps repost this while turning the "disable HTML" flag on? It's below the text field when you make a new post. You can also edit all your own posts.
Sadly the board will try to render HTML even within "CODE" blocks which messes up ChucK code because of the triangular brackets we use.
We (well, realy I personally but it works) recomend ChucKists to disable HTML when posting altogether in their profile.
