American Gladiator
Posted: Wed May 02, 2007 8:07 pm Post subject:
DIY Modular Power Source Question Subject description: DIY Modular Power Source Question |
Hello friends, I have a question for you... My current DIY project is building some Music From Outer Space modules. These modules run on 12V power, and I don't see any way to hook them into my doepfer busboard, so I was wondering if I can take a 12V DC 'wall wart' and cut the adaptor off, find out which wire is positive and which is negative, and then solder the wire directly into the PCB where the +12 and -12 connections are. I was planning on powering two more modules by just hooking cables between the respective +12 and -12 spots after hooking the first up to the wall wart thing. So could someone tell me, is this a safe thing to do? Also, will this work? Is this an electrical hazard? If someone has an answer to this, that would be great. |
RF
Audio files: 28
Posted: Wed May 02, 2007 9:25 pm Post subject:
The MFOS modules need a bi-polar supply - they need +12, -12 and Ground to work - so your plan won't do it.
There is a simple power supply listed on the MFOS DIY pages at http://www.musicfromouterspace.com/analogsynth/powersupply.html
Or you should be able to find a "Power One" 15 v bi-polar supply for sale on-line. |
Posted: Thu May 03, 2007 12:47 am Post subject:
a dc wallwart has just one output and ground. so positive output is +12V and the "negative" output is 0V. you have 12V from rail to rail.
for most of modules you will need a dual output PSU (as stated above). this could be +12V, GND, -12V. this would cover 24V from positive to negative rail, divided by the common ground. hope that makes sense?
BTW modulars are often run from +/-15V or even 18+/- sometimes and power one PSU are capable of both 15V or 12V.
concerning connecting MFOS PCBs to the doepfer bus: i just rove the 10pole ribbon cable, strip the insulation off the ends and solder the ribbon cable directly onto the PCB! you may want to use a cable tie to fiz the ribbon cable to a mounting hole of the PCB in order to release it from traction.
just in case: if you never worked with main power and you don't know exactly how to handle it, be aware: current kills. you may want to ask for help. _________________
Tech Buddy at Random*Source |
American Gladiator
Posted: Thu May 03, 2007 10:25 am Post subject:
Thanks for the help. I think I'm going to connect them to the bus board. |
synthmonger
Posted: Fri May 11, 2007 1:15 pm Post subject:
If you're using a walwart instead of a transformer like I did with the CGS PSU then I suggest using a walwart that is 3 volts above the power output i.e, 18VAC for ±15V PSU or 15VAC for ±12V PSU, etc etc. |
