flipotto
Posted: Fri May 04, 2007 6:59 am Post subject:
any midi controller 2 mackie emulation (free pc) |
Hey folks,
I have created a free (pc only) translator.
What it does, it translates your controller to a mackie control emulation.
and a mackie XT emulation.
Currrently preset is only set up for ableton live.
I suspect it will work with other software, however, I don't have much else to test it with.
download here - http://home.earthlink.net/~flipotto/ |
flipotto
Posted: Wed Jun 13, 2007 11:53 pm Post subject:
major update GenMce 1.4 check it out. |
Hello all.
I have done a major update to GenMce + GenMceXT
Sorry no pic.. but the layout has changed.
Changelog -
Removed many many unnecessary modules under the surface.
Fixed vpots -will respond much faster and more appropriately - total rewrite.
Values now output when encoder end is reached and one continues to turn.
Added midi control of vpot and jog response
Improved cpu response. Idle - 0.0% in use 0-2%, mostly under 1.5% on above machine.
Totally new style of input selection, pop up menus, much easier to work with, IMHO.
Fixed note on/offs to work, they seemed broken to me...
Total rewrite of mute select and multifunction mutes, faders, vpots.
Layout rearranged/removed some setup screens.
Moved controls and switches for, hopefully, more logical setup.
Added Transports, Cursor movement, Vpot output sections all with fixed outputs for
more streamlined setup..
F-keys now have fixed outputs, you still must define them in DAW.
Added off for many but not all non user assignable and user assignable outputs.
Reduced choices to available cc's for user assignable controls.
Note input is always push, not toggle.
Removed DAW section, now just User Commands and on 1 page.
(Many of the command outputs are static across daw software, so those are on the main setup screen.)
File size got bigger! Oops, graphic - popups!
working much better on vpots.
Try it!
Free as always. |
flipotto
Posted: Sun Mar 02, 2008 12:13 pm Post subject:
New version GenMce 1.6 - and GenMceXT1.6 |
Hi all,
Free - as always -
GenMce 1.6
Change log 1.6 - Feb.20.08
Complete redo -
*** Alas - NOT patch compatible with ver. 1.53. Sorry!
*5 new midi modules for synthedit, written by Bill Stei and hacked by myself - eliminates 1000 modules.
*GenMce.dll size reduced by 2 meg.
*Vpots - New module - 1 does the work of 500!
*Auto detect type of controller for vpots! Absolute Relative it won't matter. Genmce knows what you are sending.
*Response improved - more options, pick your favorite.
*Acceleration implemented for absolute input controllers that skip values when you turn them fast.
*Much smoother with the new vpot module, and significant cpu improvement.
*Faders - new module. Still need to get some sort of feedback for them to prevent value jumps - waiting for synthedit 1.1 and sysex
*Mutes - 1 new module for all 8 mutes.
*Cpu use reduced by 60 - 70%
*New layout, has all controls on one screen.
*New skin - trying for a more mackie look.
*Fewer user commands. not sure this will be good for everyone, but , that is the way it is.
Check it out and use it, if you like. |
flipotto
Posted: Wed Mar 19, 2008 10:27 am Post subject:
Updated GenMce 1.63 and GenMce 1.62 both final, released |
Updated GenMce 1.63 and GenMce 1.62 both final, released.
Sonar working, with procedure try it.
Working great with ableton live.
Also working with Cube/Nuendo, reaper, and many others.
Free, why not try it, pc only, sorry.
This is the last update, I am moving on to other things now.
Enjoy
http://shoshin.110mb.com/genmce/ |
