 Forum index » Instruments and Equipment » MAX/MSP - Pd
Need help with pitch or freq shifting an acoustic signal
Page 1 of 1 [15 Posts]
Acoustic Interloper
Audio files: 89
PostPosted: Sun Jan 20, 2008 4:32 pm    Post subject: Need help with pitch or freq shifting an acoustic signal
Subject description: It looks simple in the manual
After getting MAX/MSP to generate some tones to the dac with no problem, I tried inputting a mic through pfft~ through gizmo~ to so a simple pitch shift as outlined in the msp manual, then out to the dac. There is no discernable pitch shift -- it sounds like the original signal. If I break any of the connections along the signal path, the signal stops, so it appears to be flowing through my patch, but there is no pitch shifting.
I tried replacing the pfft~ -> fftin~ -> gizmo~ -> fftout~ subpatch with a simple freqshift~ up at the top level beteen the adc and dac, and this likewise has no discernable effect.
On the other hand, if I insert a lores~ filter, it definitely filters according to the cutoff freq. So, my signal path is being used, but it seems like no pitch shifting or frequencey shifting works. I checked the DSP IO settings, they seem OK. Any suggestions for a newbie to MAX/MSP? This is MAX/MSP 4.6. Thanks.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
EdisonRex
Audio files: 172
PostPosted: Mon Jan 21, 2008 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
want to post the patch? It's probably your arguments but I can't tell without looking at the patch.
Garret: It's so retro.
Acoustic Interloper
Audio files: 89
PostPosted: Mon Jan 21, 2008 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know what I was thinking, not patching the post Question Not much brain sugar left, apparently. The left side of the screen shot below is the main patch, and the right side is the subpatch accessed via "pfft~ pitch_play 512 4". I had originally brought the shifting factor into the subpatch via an "in" connection, but simplified to this for debugging. I also tried a numer box instead of a message box for the shift number. The gizmo~ man page says
The gizmo~ object implements a frequency-domain pitch shifter. It works by analyzing the
frequency bins of an FFT’d signal, finding the peaks in the spectrum, and shifting them
along the frequency axis to transpose the sound. The gizmo~ object must be used inside a pfft~
***with an overlap of 4*** or more – using an overlap of 2 will produce quite audible amplitude
modulation. When used outside a pfft~ it does nothing.
float In rightmost inlet: a float in the right inlet will be used as a frequency scalar
for pitch-shifting. Scaling the pitch by 2 will raise it one octave, sclaing the
pitch by 0.5 will lower it one octave.
int In right inlet: converted to float.
I played around with various window sizes and overlaps (>= 4) on the pfft~ and various paramaters to gizmo~ including 2.0 and 0.5 with no discernable effect.
If I break the connections from gizmo~ to fftout~, the signal disappears, so it is flowing through the subpatch. Strangely, if I leave those connections intact but break the connections from fftin~ to gizmo~, I get a distorted version of the input signal -- not a pitch shift exactly, but a distorted copy of the input, where I would have expected to get nothing. Must be something to do with pfft~ magic.
I figured I'd better get something simple working before getting serious about using FFTs. At least that was the right thing to do.
 Filesize:  24.92 KB
 Viewed:  314 Time(s)
EdisonRex
Audio files: 172
PostPosted: Tue Jan 22, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't forgotten about this. I made your patch but I need to mess around a bit with sources. Just trying to avoid firing up the whole studio over it. Soundflower isn't helping.
Acoustic Interloper
Audio files: 89
PostPosted: Tue Jan 22, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. Job hunting and my wife's newly herniated disk have been keeping me busy, but my plan is to dig through the manuals and figure out how to dump the frequency domain info for a window, and then do a "before" and "after" on the gizmo~. Any day now.
Take care.
cbm
PostPosted: Wed Jan 23, 2008 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't the gizmo~ help file illustrate exactly what you are trying to do?
Acoustic Interloper
Audio files: 89
PostPosted: Wed Jan 23, 2008 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. As far as I can tell, I am doing exactly what gizmo~'s documentation says to do, but with no audible effect.
cbm
PostPosted: Wed Jan 23, 2008 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I patched up your patch (more or less), and it worked as expected. Here it is in two parts. First the pfft part. It should be called GizmoShift.pat
Code:
#P window setfont "Sans Serif" 9.;
#P window linecount 1;
#P hidden newex 186 108 48 196617 loadbang;
#P message 146 74 17 196617 2.;
#P message 146 94 23 196617 1.5;
#P message 146 114 17 196617 1.;
#P message 146 134 31 196617 0.5;
#P message 146 154 37 196617 0.25;
#P flonum 89 174 52 9 0.0001 0 1 3 0 0 0 221 221 221 222 222 222 0 0 0;
#N in 2;
#P newobj 89 95 25 196617 in 2;
#P newex 49 192 51 196617 gizmo~;
#P newex 49 237 51 196617 fftout~ 1;
#P newex 49 66 51 196617 fftin~ 1;
#P hidden connect 10 0 7 0;
#P connect 2 1 1 1;
#P connect 4 0 2 2;
#P connect 5 0 4 0;
#P connect 6 0 4 0;
#P connect 9 0 4 0;
#P connect 8 0 4 0;
#P connect 7 0 4 0;
#P connect 3 0 4 0;
#P connect 0 1 2 1;
#P connect 2 0 1 0;
#P connect 0 0 2 0;
#P window clipboard copycount 11;
Now, the top level patch, which can be called anything:
Code:
#P hidden message 187 73 36 196617 set 1.;
#P hidden newex 187 53 48 196617 loadbang;
#P flonum 187 92 52 9 0.0001 0 1 3 0 0 0 221 221 221 222 222 222 0 0 0;
#P message 33 161 29 196617 stop;
#P message 33 138 33 196617 start;
#P newex 82 170 31 196617 dac~;
#P newex 82 120 115 196617 pfft~ GizmoShift 512 4;
#P newex 82 91 31 196617 adc~;
#P connect 1 0 2 0;
#P connect 1 0 2 1;
#P connect 0 0 1 0;
#P connect 4 0 2 0;
#P connect 3 0 2 0;
#P hidden connect 7 0 5 0;
#P connect 5 0 1 1;
#P hidden connect 6 0 7 0;
#P window clipboard copycount 8;
Acoustic Interloper
Audio files: 89
PostPosted: Wed Jan 23, 2008 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
THANKS! Having saved them to files, how do I open them in MAX to have them interpreted as patches? I tried both "Open" and "Open as Text" in MAX, and it just opens them in a text edit Window. Newbie questions. Very Happy
cbm
PostPosted: Wed Jan 23, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Max has a "New from Clipboard" command that will work with these snippets. Copy one of them, then go to Max, and select "New From Clipboard". This will create a new patcher.
Acoustic Interloper
Audio files: 89
PostPosted: Wed Jan 23, 2008 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adding a "loadbang" to my original patch did the trick. Thanks again! It looks like I'd better start reading those manuals.
This was my second patch. I drove the first from a Python program, and started out by figuring out MAX's packet protocol for numeric lists across UDP. No problems with that one Exclamation
Five string banjo across this patch sounds like playing bed springs Shocked
EdisonRex
Audio files: 172
PostPosted: Thu Jan 24, 2008 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I've learned something too.
Interesting. I had it right two nights ago, but my audio path (outside of Max) was very silly. Now i have this patch playing. Interesting.
By the way, thanks Chris.
cbm
PostPosted: Sat Jan 26, 2008 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
My pleasure.
By the way, the official Max forum has a lot of good discussions, although it can resemble a fire hose at times. http://www.cycling74.com/forums/
-C
EdisonRex
Audio files: 172
PostPosted: Sat Jan 26, 2008 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The problem with the official MAX/MSP forum (or the mail list, which I am subscribed to) is that it is somewhat uncompromising. I do not find it to be a particularly friendly place.
That said, it is a good resource, if you can master the search function.
cbm
PostPosted: Sat Jan 26, 2008 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If, by "uncompromising", you mean that it's not such a good place for beginner's questions, then yeah, it can be a little rough.
All you really have to do there, though, is show that you've done some homework, before asking questions. In particular, one thing that sets the list off is the flurry of "please do my assignment for me" questions that show up at the end of the semester.
