problem with g2 connection
Page 1 of 1 [5 Posts]
Roland Kuit
G2 patch files: 127
PostPosted: Fri Feb 08, 2008 8:29 am    Post subject: problem with g2 connection Reply with quote  Mark this post and the followings unread
i could not resist to try. but i have connected the g2 and (no connection, jan:) to VISTA. but now, my g2 cant connect to XP anymore. anybody had the same problem? any solution? switch it on gives 2 'notes' on the same freq.(pc) dung dung ,instead a high and low 'note', ding dung.
PostPosted: Fri Feb 08, 2008 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Weird ... maybe the same connection problem others have had ... scratch
Moved the message the general discussion, this doesn't have to do too much with NM to G2 conversion.
Roland Kuit
G2 patch files: 127
PostPosted: Fri Feb 08, 2008 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
thnx jan, its solved now. i had to put the g2 on/off 100 times. its working propperly again. a sort of reset. i had it once under xp too.
iPassenger
G2 patch files: 78
PostPosted: Mon Feb 11, 2008 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Arggh!! that doesn't sound good.. you'll not do that again.
iP (Ross)
astroid power-up!
PostPosted: Mon Feb 11, 2008 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
lol,
even AFTER they announced they were gonna update the drivers?
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
