little tone burst
Clack
PostPosted: Fri Feb 15, 2008 3:37 am    Post subject: little tone burst Reply with quote  Mark this post and the followings unread
I like the idea that you could use a counter as a sort of burst that would stop itself.
I adapted this from Thomas henry's 'drum cookbook' - I havnt tested it yet - I don't quite know how it works yet. possibly some things need to be removed and changed as it may be too slow. you could probably do it with other counters - this one gives a good range though of 1 to 63 repetitions.
[As stated in the post, this circuit is not tested. It's presented as an idea for discussion. --mosc]
 Filesize:  21.93 KB
 Viewed:  547 Time(s)
Clacktronics.co.uk
