music/lighting/video - software?
Page 1 of 1 [7 Posts]
faberwire
PostPosted: Thu May 08, 2008 11:14 am    Post subject: music/lighting/video - software? Reply with quote  Mark this post and the followings unread
Hello! I'm new to this forum, but it looks really cool so far.
I was wondering if anyone here might know anything about adding visuals to live performance in the form of lighting and video.
What I'd like to do is program video and lighting to sync up with the programmed backing tracks I use in live performance. I've seen this done by several artists, but I have know idea where to begin.
Also, I'm on a very limited budget, so I'm hoping to start out as inexpensively as possible.
Can anyone help me with some advice?
Thank you!
EdisonRex
Audio files: 172
PostPosted: Thu May 08, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome ... hope you continue to think this place is cool.
Back in the 70s, we low budget teens used light organs and other triggered stuff to make low budget light shows, since we couldn't afford to do more than rent dimmer packs for the weekend.
Velleman still makes light organ kits. They still work. They are cheap, too. Like $20 cheap in the states. Going DMX/MIDI will set you back a grand or so, so it's worth thinking about.
Start here. I still find the randomness of self directed lighting works great in live situations. but I don't have a lighting guy anymore either.
Garret: It's so retro.
faberwire
PostPosted: Thu May 08, 2008 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! That light organ looks very interesting, and the price is great... But I can't say that I'm sure how it actually works. Is there anywhere that you know of that would have a tutorial or more information about it?
egw
G2 patch files: 8
PostPosted: Thu May 08, 2008 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most VJ software can be triggered by midi.
Find out more here:
http://www.vjcentral.com/
Visual Jockey and OpenTZT are pretty good and are free.
www.gregwaltzer.com
EdisonRex
Audio files: 172
PostPosted: Fri May 09, 2008 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
http://en.wikipedia.org/wiki/Light_organ
faberwire
PostPosted: Fri May 09, 2008 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks egw, i'll be checking out that site right away
and EdisonRex, thanks for the wikipedia link. i guess i should have mentioned that i'd already checked that out, and i kind of get the idea of what a light organ is supposed to do. i just wonder if i order that little circuit board with a knob (that i'm supposing would be a sensitivity adjustment), how i actually connect it to lights, amps, speakers, etc. maybe it comes with instructions. i have no idea
EdisonRex
Audio files: 172
PostPosted: Tue May 13, 2008 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Usually there's an input which you drive either line level or speaker level depending on the unit, some power (local mains) and outputs to lights (usually local mains powered).
There are more elegant solutions nowadays but this is simple and cheap.
