g2 engine not responding
Page 1 of 1 [10 Posts]
astroid power-up!
PostPosted: Sat Jun 28, 2008 9:46 pm    Post subject: g2 engine not responding Reply with quote  Mark this post and the followings unread
i am despondent
i went to turn on the g2 engine-it's been working fine as always, but then today, nothing. the power light comes on, but it doesn't connect to the editor. i replaced the usb cord, even the power cord, nothing. it came on for one second to play the factory patch but then died again.
i hit the secret button on the face, it does the little one-two dance and then same deal-power led on, but no connection. any ideas?
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
astroid power-up!
PostPosted: Sat Jun 28, 2008 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok now it started working for ONE SECOND and then shut down in the same way:(
PostPosted: Sun Jun 29, 2008 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, shit.
This doesn't really sound like the USB death syndrome that some have been describing ... more like the power supply collapsing but then again the power LED is always on ?
Maybe you could open the synth to see if all connectors are seated properly ... is it expanded? if so maybe temporarily remove that to see what happens.
astroid power-up!
PostPosted: Sun Jun 29, 2008 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
it is expanded. i was thinking maybe it's a heat issue? i had it running with other gear right on top and bottom (it's not racked).
i guess i'll open it up tonight:(
PostPosted: Sun Jun 29, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking about a heat issue as well ... but when it's cooled down and still runs for a second only I'm not so sure ... I'd expect more time.
astroid power-up!
PostPosted: Sun Jun 29, 2008 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
arg.
i really don't want to try to get a soldering iron near my g2
it's so sad, i'm used to that thing being by far the most solid piece in my studio. nary a hiccup more than a restart wouldn't fix.
SadSadSad
when i check out the connectors, is there anything in particular i should look for? are there some soft plastic footings for things, or is it all soldered in?
PostPosted: Sun Jun 29, 2008 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is no use to get out a soldering iron, nothing you can do with that probably ... there are one or two short cables between the power supply and the main board, you could check those - pull those out and back in.
There is the expansion, you try to see if it will run without the expansion.
Then there is one socketed ROM on the main board, you can try to push that one down.
Then there is a connector for the keyboard, probably not an issue, but take it out snd push it in, same thing for the front panel board.
When that doesn't work or doesn't give a clue it's time for a repair man I'd say.
astroid power-up!
PostPosted: Sun Jun 29, 2008 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
does the same stuff without the expansion.
i think i'd rather trust a repair guy at this point.
arg
PostPosted: Mon Jun 30, 2008 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would be best .. I guess .. Confused
Derek Cook
PostPosted: Wed Jul 02, 2008 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I had a problem a few weeks ago with my G2 Engine, for some reason I had to reinstall the OS
http://electro-music.com/forum/topic-26835.html
Don't know if this would be a cure for your problem.
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
