loss1234
Luka
Posted: Mon Aug 18, 2008 6:17 pm Post subject:
im only just starting this but how about corel draw?
it is a vector program and you can build an object library
easy drag and drop objects and scultp traces
easy to scultp curves and shape polygons _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
SineSurfer
moosapotamus
Joined: May 11, 2007 Posts: 113 Location: New Hampshire USA
Posted: Tue Aug 19, 2008 5:16 am Post subject:
I've been using ExpressPCB for quite a while and it works great for me.
Another good one is DIY Layout Creator. The author of this software has a huge support thread going over at DIYstompboxes.
Tried Eagle several times but never had the patience to get over the steep learning curve. Seems like a great prog if you can get your head around it, tho.
~ Charlie _________________ moosapotamus.net
"I tend to like anything that I think sounds good" |
Posted: Tue Aug 19, 2008 5:56 am Post subject:
both ExpressPCB and Eagle have one big advantage: you can connect the schematc to the PCB layout and verify you layout (all points connected?).
ExpressPCB is good for their service and for creating press'n'peel layouts. it's easy to use and you can create your own devices very fast.
Eagle is usable for almost all PCB houses. it is not that easy to use but once you've got it it's great...
my 2 pence _________________
Tech Buddy at Random*Source |
loss1234
Joined: Apr 03, 2004 Posts: 24432 Location: The Netherlands, Enschede
Audio files: 297
Posted: Tue Aug 19, 2008 6:10 am Post subject:
I moved this to the developers corner as I think the layout factory was meant for layouts that are finished. _________________ Jan
moosapotamus
Posted: Tue Aug 19, 2008 6:14 am Post subject:
Ya... you can turn off the component and top layers and just display the bottom layer... and change the color of the bottom layer to black. Then do a "print screen" and paste into Word (or whatever) to adjust the size.
loss1234
moosapotamus
Posted: Tue Aug 19, 2008 7:31 am Post subject:
No special screen grab prog is needed...
Get the image displayed as big as possible on your screen and hit the "print screen" key on your keyboard. That will put a screen grab image into your clipboard. Then go to Word (or whatever prog you like that can crop and re-size images) and do a "paste".
Crop out the PCB image so there's no other junk around the edges, and resize to the actual size. ExpressPCB will show you what the exact dimensions should be.
You can also double check that pin spacing on IC's (for example) is 0.1". Or even print out the image on plain paper and place some components on it to verify the fit befor eyou print on to the PnP.
loss1234
Posted: Thu Aug 21, 2008 4:14 am Post subject:
you can just print out from ExpressPCB itself directly onto the printer, had no problem doing this using the latest version. _________________
loss1234
