Some modular synth idea
Page 1 of 1 [2 Posts]
urbanspaceman
PostPosted: Mon Oct 27, 2008 5:06 am    Post subject: Some modular synth idea
Subject description: I need some advice
hello to everyone, I recently bought a very nice briefcase that I would use to create a small modular synthesizer. the dimensions are about 25x25 cm and height used about 4 cm. I would like to create a modular synth that allow me to work with noise sounds like configuration and then I thought: 2VCO 1 or 2 Noise VCF, VCA, RINGMOD ... and other things to fill it all. What me? of course I would build all and I spend quite little.
should be well synth with a single pcb. I'd love to have a scope like this
The idea is to create something similar to the bug brand drone machine but in a smaller space.
Thanks in advance
noisedeputy
PostPosted: Sat Nov 15, 2008 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
well bugbrand has a lot of their schematics on their site. The drone machine uses a lot of 40106's for the OSC's right? I forget what else, but a lot of the circuits are really simple, if you look around the site you will find a lot of the schematics needed right there. After that, it's up to you to make the parts small enough, as well as the face panels etc.
