Quick question about the baby 10
Page 1 of 1 [7 Posts]
stolenfat
PostPosted: Fri Oct 31, 2008 9:33 pm    Post subject: Quick question about the baby 10
Subject description: battery operation
Im in the middle of building a baby 10 tonight, i posted in another forum but didnt get the reply i wanted... sooooo
Can the baby 10 be run off of a 9volt battery?
The schematic calls for 15 volts, could i chain 2 9volts together to get 18 volts then use some voltage regulators or a chain of resistors to bring it down to 15v?
I'd much rather just use a 9volt!
e45tg4t3
PostPosted: Sat Nov 01, 2008 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
hi there,
i rum my baby 10 on 9 volt with no problems.. the only thing you should may change are the led resistors... just to suit them to the 9 volt instead of the 15....
Benny
PostPosted: Sat Nov 01, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
there is another advantage of using just 9V. the counter ICs trigger theshold is half the supply voltage.
so without using a trigger conditioner the common baby10 powered from 15V would require trigger signals of more than 7.5V...
stolenfat
PostPosted: Sat Nov 01, 2008 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
so dig this, i finish it up right, i test it- nothing. Just one long tone. Anyways i go back and forth to try and fix it, checking my solders and stuff.... and blam I broke my soldering gun!
Bug!
stolenfat
PostPosted: Mon Nov 03, 2008 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
i dunno homies. I built up the baby 10 rip off from curious inventor and kinda got that to work but it stuck at step 6 (weird)
then unhooked everything and tried the regular baby 10 schematics and didnt really get anything from that either. I mean it kinda worked... it seems multiple knobs effect the cv out on different steps. I havent hooked up a clock yet, just tapping the clock in the +v of the 9volt to get it step a quasi-random amount ahead. also, i used 1k resistors on the leds and they're very dim, maybe i should trim those down too.
stolenfat
PostPosted: Mon Nov 03, 2008 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
garrr.... I'm looking through all my forest mimms stuff and cant find a schematic for a 555 clock generator- any one got a good schematic to run my 4017?
TheAncientOne
PostPosted: Thu Nov 20, 2008 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
This thread may help, and it includes a clock generator reference.
http://electro-music.com/forum/post-116272.html
Mike
