Octave doubler
Page 1 of 1 [2 Posts]
Perejil
PostPosted: Mon Jan 19, 2009 9:59 am    Post subject: Octave doubler Reply with quote  Mark this post and the followings unread
I feel like i'm hogging the board with my questions but here we go.
What's the simplest way to make an octave doubler? What is want to do is have switches for different timbres (obviously most of them will be waveforms) but i want one that adds on the first harmonic (1 octave higher).
What's the simplest way of doing this?
If this is a complicated procedure then a sine wave on its own will suffice.
"In the context of Philip, hair is dissonant." - An explanation of Schenkerian theory by Dr. J. P. E. Harper-Scott
Audio files: 296
PostPosted: Mon Jan 19, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It depends on the waveform you want to double ... for a triangular wave you can use full wave rectification followed by a DC shift, and for a sine the signal can be multiplied by itself, followed by a DC shift ... the outgoing wave shape will then be the same as the ingoing one.
