WANTED:Simple, cheap, schematic drawing software for Windows
Page 1 of 1 [9 Posts]
cappy2112
PostPosted: Wed Jan 21, 2009 12:43 am    Post subject: WANTED:Simple, cheap, schematic drawing software for Windows Reply with quote  Mark this post and the followings unread
If you can receommend something, please do.
I dont need to do board layouts or gerber plots or anything that exotic.
Just a good, easy to use program for drawing (and printing) schematics.
thanks
spippoli
PostPosted: Wed Jan 21, 2009 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
have a look at
http://www.musicfromouterspace.com/SchematicEditorPromo/schematicpubwebpage.html
JovianPyx
Audio files: 224
PostPosted: Fri Jan 23, 2009 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go ahead, laugh if you want to...
Much to the astonishment of many, I use the Paintbrush program that comes with Windows. I created a document which has symbols on it that I use regularly. It makes neat schematics that can be saved in GIF format for small size.
I have posted my symbols image file as an attachment to this post.
document containing basic part symbols
 Filesize:  14.56 KB
 Viewed:  502 Time(s)
Time flies like a banana.
corruptio optimi pessima
PostPosted: Fri Jan 23, 2009 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing when this thread started I was thinking I could use such a set as you just posted, so thanks doing so! Oh, and I'll be using it the same way.
JovianPyx
Audio files: 224
PostPosted: Fri Jan 23, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're quite welcome Mr. Blue. And that is all original artwork I banged out using PB, so there's no copyright nonsense to worry about. It's free.
If you want to see some complete schematics I did with PB, go to my FatMan mods page (see sig) and look around.
PostPosted: Fri Jan 23, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good, I'll probably translate resistors, polarized caps & ground symbol into dutch Wink
richardc64
Audio files: 26
PostPosted: Fri Jan 23, 2009 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, me too! The "jaggies" take me back to my Commodore64 days! I started out, um...borrowing others' symbols from the 'net, then editing them to my liking. Haven't quite settled on a style, yet.
My "library" isn't as well organized as yours, but if I need something I've already drawn, I know where to find it. For now.
françois
PostPosted: Sat Jan 24, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
I use Microsoft Visio, for which I designed a library of component symbols. This is clearly overkill, since Visio is expensive, not included in Microsoft Office (it is compatible of course, but you have to purchase it separately). Since I have it for professional work anyway, I use it.
But Visio is not only a drawing tool, it is more a graphical interface for database applications. As such, it can automatically number all components, edit their properties (e.g. value for a resistor, type for a transistor) and automatically generate a bill of materials. Including the costs if you wish.
Every component has connection points, and when two components are wired together the connecting lines are adjusted automatically (you can adjust them by hand if you want), including the little "jumps" when two lines cross. When a component is moved, the connecting lines are updated.
For the component symbols, I scanned a number of schematics from Elektor because I like their style, and I reproduced them. Attached is an example schemo.
There is a cheap alternative to Visio: Edraw Max. I got it for free from giveawayoftheday.com but it was only a one-day offer. However the full software should cost about 20.00€, which is admittedly more reasonable... and it is fully Visio-compatible!
Yours,
-- françois
 Filesize:  30.5 KB
 Viewed:  448 Time(s)
picsynth
PostPosted: Tue Feb 03, 2009 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use this package - its easy to use and free:
http://www.expresspcb.com/ExpressPCBHtm/Free_schematic_software.htm
