 Forum index » Instruments and Equipment » Nord stage
Need advice on how to imitate an Irish flute
Page 1 of 1 [4 Posts]
kerij
PostPosted: Tue Apr 07, 2009 5:45 pm    Post subject: Need advice on how to imitate an Irish flute
Subject description: synth an irish flute
Has anyone played with the synth section to imitate an Irish flute/ tin whistle? I know I'll use the pitch bender to play it live, but I don't know how to synthesize the actual sound. Thanks- any info would be helpful!
gearaholic
PostPosted: Thu Apr 09, 2009 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
push synth init and choose the sign wave
set the filter freq low to leave only the fundimental
octave shift up
select mono w fast glide
hope it helps
kerij
PostPosted: Thu Apr 09, 2009 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I'll give it a try
peterkadar
PostPosted: Mon Apr 13, 2009 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can try adding some noise from the synth section on panel B to get more of the blowing effect. You could even use an envelope to shape the noise component to sound like the initial burst of air you sometimes hear with a flute.
Also, if you make it trigger in a mono-legato way, it'll only retrigger when you play a new phrase, not unlike the real thing.
