Clone PCB from scanned image
Page 1 of 1 [15 Posts]
tonewill
PostPosted: Fri Oct 16, 2009 5:57 am    Post subject:  Clone PCB from scanned image Reply with quote  Mark this post and the followings unread
I had an idea to create a clone of an old PCB from a scan taken of it. I have scanned the track side of the board and played around in photoshop using colour selection and smoothing, but I'm sure that it would be possible to get much better results with much less manual touch-up work needed with the right know-how.
Anyone tried this or know of a tutorial somewhere?
Peake
PostPosted: Fri Oct 16, 2009 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly how I am attempting to clone some Moog and Buchla modules. It is possibly the worst possible method to use Laughing Real caveman stuff. Someone will now chime in with streamlined, modern technology and a good chuckle at my expense. Best luck! (Be sure to put corner markers and possibly even a thin edge outline for board cutting.)
However, if the transfer methods allow for good double-sided results, it will have been worth every moment spent.
julian
PostPosted: Fri Oct 16, 2009 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ive created tool paths (for isolation milling) from scanned pcbs before.
I did not personally do the scanning but i believe that they were scanned (or possibly even photographed) and then printed onto paper, retouched using a physical pen, and then rescanned again.
I then used a trace function to create a tool path for milling the copper from the bare board to leave the traces, but for other reasons the board was never produced.
Obviously this is only possible on single side boards without removing all the components!
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
parasat
PostPosted: Fri Oct 16, 2009 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
julian, when you say "trace function," is this part of your CAD/CAM software (and if so, what are you using)? Or is it a module in another program, or something you wrote yourself?
Enquiring minds want to know Smile
Sebo
PostPosted: Fri Oct 16, 2009 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
I did a PCB copy of my DR-110 that way, scanned it, then used Photoshop
treshold funtion to convert it to a monochrome kind of pic, then I worked
it by hand. I set a layer with the original scan set to 50% opacity to guide
me, and turn it on and off as I need it, and to verify is an exact copy.
I etched the PCB but never find the time to drill it, so is laying around unfinished
(as many other projects).
Sebo
My Music:
scriptstyle
PostPosted: Fri Oct 16, 2009 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
the "trace" function may be live trace in illustrator? honestly that would be the direction i would go in after adjusting my levels in photoshop, then i would select all the black, invert, delete, save as .psd import into illustrator trace and expand. then make adjustments.
drapdap
PostPosted: Sat Oct 17, 2009 2:29 am    Post subject: Re: Clone PCB from scanned image Reply with quote  Mark this post and the followings unread
hello guys...
i'm doing this method quite confortably since a while. (mind you i'm livin from doing graphics and animation.)
let me tell you that tracing these is a complete waste of time, i've been there, done that, tried setting up things in photoshop or gimp,
do equalising, do color selection, get it just about right, than try to trace it with flash, or inkspace, (i'm not too fond of illustrator at all) but there will be always smaller or bigger errors which you have to deal with by "hand". So why not work clean from the start, make a layer for you new pcb and draw over the traces. It doesn't need to be a scan, a good quality picture works too, i just free transform them until they don't distort the size.
Usually i give them better resolution (300-600 dpi) then go over the holes with creating a circle with a hole on a seperate layer, selecting it, and then move a copy of that over each component hole for a start. Same for the ic's, i just have these pre-saved, right size component drawings in a pdf-file...
my Wacom-tablet is my best friend for joining the dots, but with the photoshop selection tool you can get pretty far too, looking quite pro.
But anyway, i just wanted to tell you that from experience, this is a lot better method, almost the same, but better than try to clean a dirty scan, that's really caveman stuff, it eats time.
Attached is a redrawn Serge 1973 TWS (kit), from Ken Stone's site...
http://www.cgs.synth.net/synth/serge/tws.html
Strictly for edjucational purposes.
This was one of the first boards i did this way, looks still shakey, i do a lot better now, but that didn't stop me from building a working copy of this.
(I hope it's ok to post, dear Admins, this is old stuff, and up on Ken's site anyways...)
Now is there somebody with a good picture of the Serge Wavefolder? Smile
róbert
Serge_TWS_0.6_PNP_A4.pdf
 Filename:  Serge_TWS_0.6_PNP_A4.pdf
 Filesize:  902.9 KB
 Downloaded:  281 Time(s)
Peake
PostPosted: Sat Oct 17, 2009 10:25 am    Post subject: Re: Clone PCB from scanned image Reply with quote  Mark this post and the followings unread
drapdap wrote:
So why not work clean from the start, make a layer for you new pcb and draw over the traces. It doesn't need to be a scan, a good quality picture works too, i just free transform them until they don't distort the size. róbert
That's what I'm doing...however, on the Moog, the boards are populated (single-sided). It is possible, following the schematic along with the traces, to make sure that every through hole is correct and each trace accurate.
drapdap
PostPosted: Sat Oct 17, 2009 10:52 am    Post subject: Re: Clone PCB from scanned image Reply with quote  Mark this post and the followings unread
Hi Peake!
yeah, checking the thing against the schemo is always necessary, i totally agree on that...
but redrawing helps me understand the circuit most of the times, so it becomes easier to modify the layout...
but parts today are so small that i sometimes end up shrinking a board, except for the sockets, so i keep them on a separate layer usually.
it starts to get messy by that time, so i always wonder by the end why didn't i start the whole thing in Kicad...
is it possible to know which Moog are you working on?
Somebody just posted the Minimoog-D pcb scans a while ago, but the
admin here (most rightfully) removed them quite quickly...
r.
Peake
PostPosted: Sat Oct 17, 2009 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, just the 901a/901b so far; when they're ready I'll post them (I have Moog Music's kind permission, and no one is manufacturing them so there is no conflict of interest).
Note that these use 1/2W resistors, so the boards are huge and the spacing very, very kind to those who hand-draw clone PCBs Very Happy
The artwork is ready but I lack any knowledge of how to "select" the specified 2N 4058s (probably voltage matching). Cheers!
TekniK
PostPosted: Mon Oct 19, 2009 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
drapdap -> i did redraw the ringmod from kens site that way.
tonewill
PostPosted: Mon Oct 19, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks everyone, I think you're right, re-drawing the tracks is the way to go.
etaoin
PostPosted: Wed Oct 21, 2009 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I've redrawn scans using Abacom's Sprint Layout, which might be the only pcb design program that let's you use transparent scans. It probably easier than something like photoshop since you can use the parts library to get the right footprints. And a lot cheaper than photoshop as well...
http://www.casia.org/modular/
Peake
PostPosted: Wed Oct 21, 2009 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip, that sounds like just the right thing!
drapdap
PostPosted: Thu Oct 22, 2009 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip Etaoin!
Teknik: yes, Ken Stone's wonderful site is a sitting duck for people who'd rather spend time redrawing things than buying boards... i also did lots of things from there by looking at the pcb's and reading the schemo's while joining the dots, the psycho Lfo, the real ring, the small wavefolder, the bandpass filter, the burst generator, all simple but wonderful little circuits... I believe Ken knows this, otherwise he'd do double sided boards without pictures on the net, but how would you be hooked than? the first must always be free... Smile
This pcb thing became like a card-game, collect all of them, who got the most wins. i really enjoyed getting into things a few years ago by diy-boards (free on the net, etched my own), it did fire my imagination, mind you, im not too fond of collectors, i just envy the knowledge. Also i see a value of an instrument is the time i've spent with it... of course there are better or worse violins, but one can play violin or not. And that's just time and dedication.
As for the Ring Modulator on Ken's site, it's hard to credit it to him, as it's in almost every older book about electronics or ham radio along with the balanced modulator, i've known that drawing from my dads books years before i got to make my own... Of course a layout is another thing...
erm, sorry for ego-trippin...
róbert
