 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Live relativ controler remote
Page 1 of 1 [2 Posts]
3phase
G2 patch files: 141
PostPosted: Tue Oct 12, 2004 9:14 am    Post subject: Live relativ controler remote Reply with quote  Mark this post and the followings unread
Various versions for remotes for ableton live inkl Live template...
I hope i can have multiple attachments...
Clavia G2 Remote for Live 3 und 4.
Live 3 Remote supports the track solos. Live 4 has still problems with that. (V 4.03 only can switch the solos with notecommands what gives no visual feedback on the G2)
The Live 4 Remote can switch the solos with the keyboard. The lowest octave. You have to press shift/octave down to switch the keyboard globally down to the lowest cktave. The next octave higher is doing the mute buttons. While the highest possible key stops all clips. One key lower starts scene one.
Live 4 remote has some midi feedback from Live to the G2 therefore
pressing “HomeStop” stops all clips and than jumps to the first scene of the choosen section.
Live 3 remote only jumps back to the scene that was selected before pressing the “HomeStop” button.
In Live 4 Home jump can be deactivated with knob 8E3.
G2 patches are for Slot D, channel 4
You have to select the G2 as a remote source and maybe destination (in case you want to see changes in Live  on the G2) in the Live preferences.
Track 13 on the Live 4 remote has to adress the G2 with its midiout..
These patches require an Live Session that contains 65 scenes…otherwise the scene collector don’t works correct. Therefore if you insert a scene you have to remove another instead.
There is a eco version of the Live 4 remote that don’t allows switching of the
Channel levels. This safes 20% Dsp.
Live 4 remote eco (no level switches) ca.43%
Live 4 remote standard ca. 63%
Live 3 remote ( with solo buttons) ca. 82%
The red skin for Ableton Live you can find on the webpage of Robert Henke, www.monolake.de It is in a set of skins only for Live 4 and called mono_13.ask
I ve boosted the green in my colourprofile a bit because i like that in generally… Maybe the skin is on other computers more pink than red Wink
3phase 09/04
 Filesize:  92.6 KB
 Viewed:  8482 Time(s)
3phase
G2 patch files: 141
PostPosted: Tue Oct 12, 2004 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Evil or Very Mad
And here the files... hope it works now
LiveRemG2.zip
 Filename:  LiveRemG2.zip
 Filesize:  132.93 KB
 Downloaded:  775 Time(s)
