drapdap
Posted: Thu Dec 17, 2009 6:02 am Post subject:
CGS77 - Serge VCF Subject description: news from 1973 |
Thank you sir Stone!
im just staring at the schemo... feels like an early xmas present.
http://www.cgs.synth.net/modules/cgs77_vcf.html |
LetterBeacon
Posted: Thu Dec 17, 2009 1:56 pm Post subject:
Wow, very exciting!
Are there any demos available? |
drapdap
Posted: Thu Dec 17, 2009 2:25 pm Post subject:
| LetterBeacon wrote: | Wow, very exciting!
probably as it seems this is an the old serge classic, might be tons of records this one is featured on.
http://www.cgs.synth.net/synth/serge/vcf.html
this one, plus a buffer...
this might be a state variable filter?
beautiful stuff ... |
LetterBeacon
Posted: Sun Dec 27, 2009 4:59 am Post subject:
I'd just like to confirm something:
To use the TL074 buffer section I would, instead of wiring as shown on the wiring diagram, connect the HP BP and LP outputs to the TL074 inputs and then the TL074 outputs to the sockets?
I don't understand the setting up instructions:
| Quote: | | Adjustments on the vcf board are basic. Set trimmer so that the VCF's center frequency as at an appropriate pitch. |
I don't understand what an appropriate pitch is! |
widdly
Posted: Tue Dec 29, 2009 10:42 pm Post subject:
The trimmer just adds an offset voltage to the frequency CV summer. If you set the Cutoff knob to the middle you can change what frequency the middle will be by changing the trimmer.
I don't know what real serges use but looking at moog or arp front panels show the filter cutoff centre is usually 500Hz so that would be a good place to start.
fluxmonkey
Posted: Fri Feb 12, 2010 5:04 pm Post subject:
hmm... just noticed this on kens page for the Serge filter: "Those assembling the Euro version of this module..."
hotdamn. _________________ www.fluxmonkey.com |
jnuaury
Audio files: 9
Posted: Thu Feb 18, 2010 9:31 pm Post subject:
| bbob wrote: | hmm... just noticed this on kens page for the Serge filter: "Those assembling the Euro version of this module..."
hotdamn. |
the full quote says
"Those assembling the Euro version of this module will need to substitute two of the regular pots and the spst switches for combined units available from Mouser. P/N: 313-1600F-50k "
this is probably copy-pasted over from the VCS page
unfortunately the VCF has no switches so theres no need for theres mouser parts so theres probably not a euro board planned.... _________________ az/gde
Flickr
YouTube |
andrewF
Posted: Thu Feb 18, 2010 10:33 pm Post subject:
| jnuaury wrote: |
unfortunately the VCF has no switches so theres no need for theres mouser parts so theres probably not a euro board planned.... |
there can be a switch -
also from the VCF page - "A DPDT switch can be added to short points F and G to 0V. Doing this will switch the filter into low-frequency mode, as per the VCFX (for CV filtering etc.). While the original Serge boards had this function, it is doubtful it was ever brought out to the panel. "
this is a worthwhile mod, CV filtering is and a rather unusual feature for a VCF. |
macumbista
Posted: Sun Jul 25, 2010 9:40 am Post subject:
Built a pair of these a few months ago, just want to chime in that they are SWEEEEEET and well worth the time and expense. You can probably hear plenty of this filter in these tracks.... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
macumbista
Posted: Sun Oct 03, 2010 1:52 am Post subject:
Is anyone else finding that the CV inputs go wild really quickly? Seems like way more than 1V/Oct. Just a little tweak off center in either positive or negative direction and the modulation is extremely wide. I'm using 25K lin pots instead of the listed 20K, but that shouldn't account for such an extreme amount of input. _________________ Esoteric drones and nonlinear distortion
macumbista.net |
j.dilisio
Posted: Tue Oct 12, 2010 11:45 am Post subject:
Hey Macumbista, what's the password to unrar that Serge Mix? _________________ DRONEGOAT |
macumbista
Posted: Tue Oct 12, 2010 3:57 pm Post subject:
| j.dilisio wrote: | | Hey Macumbista, what's the password to unrar that Serge Mix? |
It's in the blog post, just below the DL links... "orpheusmachine" _________________ Esoteric drones and nonlinear distortion
macumbista.net |
j.dilisio
Posted: Tue Oct 12, 2010 5:27 pm Post subject:
Aaah! So it was right in front of me.
Cheers _________________ DRONEGOAT |
xi-boy
Posted: Mon Oct 15, 2012 7:27 am Post subject:
| macumbista wrote: | | Is anyone else finding that the CV inputs go wild really quickly? Seems like way more than 1V/Oct. Just a little tweak off center in either positive or negative direction and the modulation is extremely wide. I'm using 25K lin pots instead of the listed 20K, but that shouldn't account for such an extreme amount of input. |
this filter has become one of my favorites
its specially brilliant for pinging sounds
but probably because of its wide cv range (?) its resonance loves to freak out ;-(
also the bipolar attenuator dosent close completely
i actually would prefer a uni polar attenuator
any idea how to make this filter more controllable ? |
LetterBeacon
Posted: Fri Mar 29, 2013 10:01 am Post subject:
| widdly wrote: | The trimmer just adds an offset voltage to the frequency CV summer. If you set the Cutoff knob to the middle you can change what frequency the middle will be by changing the trimmer.
I don't know what real serges use but looking at moog or arp front panels show the filter cutoff centre is usually 500Hz so that would be a good place to start. |
What setting are people using for their filters? How are you guys measuring the frequency that you're setting it at? |
wackelpeter
Audio files: 10
Posted: Mon Jun 29, 2015 12:41 pm Post subject:
digging that old thread out as i still need a VCF for my 4th "synthcase"
already have plenty of others in my other cases but i definitely wanted to build a serge VCF too...
As i don't have those gain cells for the VCQ VCF i'm stuck to this one...
have all material form the BOM except the J201...
can i substitute them with 2n3819 or 2SK30 which are also N-Channel FET's?
would this work?
Any advice would be welcome...
cheers Bastian _________________ https://soundcloud.com/bastian-j |
wackelpeter
Audio files: 10
Posted: Thu Jul 02, 2015 10:07 am Post subject:
well, can answer my last question now on my own... yes it works with 2SK30... probably not as in the original but i think it Sound smooth and fine...
what makes me wonder is that my filter does self-oscillate without those modifications Ken mentioned on his site... hmm... and the volume doesn't drop either it increases a lot... _________________ https://soundcloud.com/bastian-j |
