VCLFO ~ Ramp/Saw, Square not working
Page 1 of 1 [5 Posts]
gddfp
PostPosted: Sun May 30, 2010 1:52 am    Post subject: VCLFO ~ Ramp/Saw, Square not working Reply with quote  Mark this post and the followings unread
The VCLFO is my first MFOS build.
Sine & Triangle outputs work just fine. CV inputs, Coarse & Fine all work properly. As does the LED.
However, the Saw & Ramp outputs sit at an alarming, steady +10.5V and -10.5V respectively, and the Square output stays at +4V.
I've wired up an attenuator (100k) to the PWM input (wiper to PWVX, CW to socket, CWW to GND).
I am a relative beginner, and not very well experienced at debugging (yet)... Where should I start looking ? I suppose I should concentrate on U5 & U6, so what voltages should I see at which pins ?
I've already checked for the typical basic-level debugging stuff like shorts, bad solder points, etc...
tia !
_guy
slacker
PostPosted: Mon May 31, 2010 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The first thing I would do is check that Q4 and Q5 are in the correct way round. If they were backwards that would stop any signal getting to U5 and U6.
gddfp
PostPosted: Mon May 31, 2010 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Unless J210's have different pinouts than MPF102's, they are correctly seated.
Oh wait, I'll go check that myself first...
thanks,
_g
gddfp
PostPosted: Mon May 31, 2010 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same pinouts.
I wired up my second VCLFO, this time with J201's instead of the J210 [MPF102], and left out the wiring of (my) attenuators for the CV inputs (*) and PWM.
Worked right off the bat.
That'll make debugging nr.1 easier, I reckon.
(*) The CV attenuators do work on the other module; just left them out for clarity in the 2nd module.
_g
gddfp
PostPosted: Wed Jul 07, 2010 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
After a lot of head-scratching, I found the problem.
A faulty TL082 (U5).
This happened before with the TL07/8 series.
I've got two VCLFO's happily pulsating now...
_g
