G2X extra mod wheel assignments?
Page 1 of 1 [3 Posts]
SayersWeb
PostPosted: Mon Nov 29, 2004 7:34 am    Post subject: G2X extra mod wheel assignments? Reply with quote  Mark this post and the followings unread
Has anyone successfully assigned morphs to either of the extra mod wheels on the G2X?
I tried yesterday without success. No problem assigning morphs to the standard mod wheel, but when I try the extra mod wheels the morph does not work. I even used the copy feature to go from the standard mod wheel (which had a working morph) to the extra one, but it still did not work.
Any suggestions?
Sayer - Home Page
Wan
G2 patch files: 46
PostPosted: Mon Nov 29, 2004 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Just checking, you do click on the button under the morph knob to enable the wheels? They are disabled by default...
Grtz Wan
SayersWeb
PostPosted: Mon Nov 29, 2004 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hoi Wan!
I was able to geth them working by turning them on in the editor. I had only tried it from the hardware interface.
I'm not sure which button & morph knob you refer to.... I can't seem to find the switch on the hardware interface to turn them on. Once they were activated in the editor the morph assign works fine from the hardware interface.
At least it worrks! I was worried for a little while. Smile
Thanks,
Sayer
Sayer - Home Page
