Fun stand-alone modules
Page 1 of 1 [8 Posts]
rich decibels
PostPosted: Sun Sep 05, 2010 4:10 pm    Post subject: Fun stand-alone modules
Subject description: Suggestions wanted for exhibition
Hi everyone, I'm putting together some Lunetta modules as part of an exhibition showing in November. I'm looking for suggestions of what to build. I want each module to be an interesting unit on its own. The first design I'm settled on is a 4-stage 4093 gated oscillator like this one I made.
I think the 4093 is ideal because it satisfies these requirements:
- one IC
- endless audio possibilities
- highly musical but still glitchy
- minimal controls (4 pots)
- easy to add blinky whizzbang leds
- no instruction manual necessary
Can you suggest anything similar? Thanks!
Rich
urbanspaceman
PostPosted: Mon Sep 06, 2010 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hì Rich, you have the wiring diagram for the 4093 ?
tnx
corex
PostPosted: Mon Sep 06, 2010 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
tnx
I imagine it's similar to this one?
http://www.fluxmonkey.com/electronoize/4093_Oscillator.htm
urbanspaceman
PostPosted: Mon Sep 06, 2010 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Perfect, tnx!
tjookum
Audio files: 26
PostPosted: Mon Sep 06, 2010 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just want to add that in my personal opinion the best values are 1meg for the pot and 0.047uF for the caps. Adding a switch to choose between 2 or 3 different caps is also a nice addition.
For a simple module with good musical potential you can't beat a melodygen and 4 oscillators (or 1 and a divider). Another great way to get good metalic glitchy sound is to add a 4070 XOR gate IC. Look around, there are plenty of cool ideas here.
Hunter S. Thompson
movies
noise
stolenfat
PostPosted: Thu Sep 16, 2010 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
if your circuits are going to be on 'display', use photocells instead of pots. I've noticed people love to play with dem photocells (plus its cheap!)
get some long wire so people from different corners of the room can play with the photocells and interact with the same circuit.. and suddenly its art!
tjookum
Audio files: 26
PostPosted: Fri Sep 17, 2010 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I just made this for a class in art school:
Hunter S. Thompson
movies
noise
stolenfat
PostPosted: Fri Sep 17, 2010 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
hahaha, that is so awesome!
