electri-fire
Joined: Jul 26, 2006 Posts: 536 Location: Dordrecht NL
G2 patch files: 4
Posted: Wed Sep 22, 2010 1:13 pm Post subject:
EM2010 Lunetta Workshop after support Subject description: For questions, remarks etc. |
Thank you Kevin and Eric, Mike, Kevin, Rebecca for attending the workshop.
Things that pleased me:
I "think" everybody got "some" idea of what Lunetta building is about.
I have gotten across the "Les Hall Neatfreak Staple Method" for breadboarding (though Rebecca has been reluctant to pursue the method ) .
I do recommend to use the staple method when keeping your Lunetta on breadboard. Some of you will be transferring circuits to soldered versions, in wich case it's less of an issue.
Things disappointing:
-I planned to show you loads of other things, but didn't get to it.
Reason for this not having happened:
1-Lack of time. We could easily spend two afternoons doing this.
2-Chaos. Noise. People coming in and out. My inbuilt tendency to being disorganized. Next workshop I'll be locking the door .
-Not doing the Lunetta Maelstom. Due to things I thought being unfinished. Kevin and Eric had been tinkering at their boards on their own, so in hindsight we could have done something. Make a racket at least.
Lunetta building and using takes some getting used to. You'll have to invest some time in discovering the possibilities and overcome technical issues.
The bright side: We (electri-fire and the rest of the Lunetta community reading this) are here to assist you with your Lunetta builds and technical bottlenecks. You'll be posting cool setups and sounds in no time.
Read the Lunetta Forum. Let us hear how you're doing. Thanks again. |
electri-fire
G2 patch files: 4
Posted: Wed Sep 22, 2010 1:24 pm Post subject:
This CMOS pinout collection:
http://electro-music.com/forum/topic-44146.html
I had printed out for you as a reference , but I left the prints at home and forgot were I downloaded it. So I got you a different set of prints, but these have more IC's and are more readable. |
Joined: Mar 28, 2006 Posts: 1468 Location: Kansas City, Mo USA
Posted: Wed Sep 22, 2010 2:18 pm Post subject:
Thank you, Mathe for a great workshop |
This workshop was very useful to me.
For starters, it was helpful to learn organized methods for laying out the power and ground busses and to learn how to populate the breadboard such that one can easily transfer a working prototype to a schematic.
I've already put this to use -- the Envelope Generators on my Aries synth pulled too much current and I designed simple voltage followers (with large input resistors (1 meg). From breadboard, into Eagle, and an etched PCB was a breeze!
The beginner Lunetta thread speaks about pulldown and pullup resistors however the workshop made it clear as to their purpose and implementation. While one can read about things, it is often useful to actually see it being done.
I am now designing a PCB that simply accommodates a "virtual" 18 pin socket with corresponding traces and pads and space for other components (such as resistors, diodes, and pots). Why 18 pin? The reason is so that I can place 14, 16, or a pair of 8 pin sockets.
I envision a Lunetta that is a kind of "modular synthesizer" wherein each chip is a "module". I plan to utilize banana plugs and go for something that is not too hard to transport. My ideas are subject to transformation -- once I get into the project I'm sure I'll think of things that I can't anticipate at the moment.
Eric and I both had a great time and look forward to next year. By golly -- we will manage a Lunetta concert next time!  _________________ -- Kevin
http://kevinkissinger.com |
tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Thu Sep 23, 2010 2:31 am Post subject:
Man I really wish I was there to join you guys, ah well, maybe next time.
| Quote: | | While one can read about things, it is often useful to actually see it being done. |
This is especially true when working with cmos/lunetta's, I really support the choice of electri-fire to start on breadboard. Once you start seeing the flow of things it might be usefull to have some of them permanently soldered, but the whole process starts on the breadboard(at least for me it does).
Great to see more and more people getting excited over this. Im still hoping Stanley Lunetta drops in some time, I wonder what he would make of this . _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
electri-fire
G2 patch files: 4
Posted: Thu Sep 23, 2010 7:04 am Post subject:
Re: Thank you, Mathe for a great workshop |
| kkissinger wrote: | | I am now designing a PCB that simply accommodates a "virtual" 18 pin socket with corresponding traces and pads and space for other components (such as resistors, diodes, and pots). Why 18 pin? The reason is so that I can place 14, 16, or a pair of 8 pin sockets. |
That would be a useful thing to have. Might we have a look at your layout when you're finished?
| kkissinger wrote: | | I envision a Lunetta that is a kind of "modular synthesizer" wherein each chip is a "module". |
That's how it's done very often. However one could also make combinations of chips with "hardwired" connections that can be used as a module.
Hardwiring reduces the number of in/outputs and the need of extensive wiring. It also reduces cost. ICs are much cheaper than panels and in/outputs.
Coming up with nice and versatile multi chip modules is a sport in itself. The two chip "Melody Generator" designed by Slacker has been well received and is used by several builders. Some even have two of those in their Lunetta. |
