Using your Nord with a sequencer
Page 1 of 1 [2 Posts]
Ligumo
PostPosted: Wed Dec 08, 2010 1:53 pm    Post subject: Using your Nord with a sequencer Reply with quote  Mark this post and the followings unread
I'm curious to know how Lead, Rack and Wave users are using their Nords - as a stand alone instrument or with a sequencer? And how do you have it routed?
The reason I ask is that up until very recently I was using the 4 independent outputs on my NR2X for each channel, therefore having four seperate voices which I could treat individually, running into the M-Audio Delta 1010LT I had on my desktop.
Now I've downsized to a laptop setup with a 2-input Focusrite interface, I'll either be tracking individual voices a lot more, or combining them into the stereo output.
Also, what sequencer are you using, and what challenges do you have with it? I'm using Cubase 4.5 on a PC. I also have Propellerhead Record 1.5 (which I much prefer), but until they introduce MIDI out, I have no way of using my 2X with it! I find Cubase very annoying, too much technical work getting it set up right!
Nord Rack 2X
Cubase Studio 4
NI FM8, Battery 3, Guitar Rig 3,
Propellerhead Recycle, Reason 6 (NO MIDI OUT!?!)
Gibson Les Paul Deluxe (1980)
Rickenbacker 330 (2003)
Peavey Milestone III with SD Jazz Bass pickups
www.ligumo.com
www.soundcloud.com/ligumo
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 08, 2010 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stand alone,,,
A gig rack containing a Lead2 and a Rack1, the later uses the Audio in of a Modular Rack which is placed on top of the lead.
I mostly use the arpeggiator of the Lead2 and always Performances in both leads, so PCMCIA cards are important.
Wout
