Page 1 of 1 [4 Posts]
seaweedfactory
PostPosted: Sun Dec 16, 2012 2:52 pm    Post subject:  . Reply with quote  Mark this post and the followings unread
Last edited by seaweedfactory on Sun Jul 06, 2014 7:23 pm; edited 2 times in total
PostPosted: Fri Dec 21, 2012 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
the clock enable is ON when tied to ground, and OFF when high (inhibit). when i take a look at the datasheet then i see that the clock enable is nothing but a non-inverted input to an AND gate, where the clock is fed inverted.
the ken stone circuit shows comparators. this is good, because the 4017 need more than 1/2 of the supply voltage to clock (2/3 IIRC?).
so i cannot see why a comparator shouldn't work, all the more when you used a pulldown resistor. just use the same configuration as for the clock's comparator. (or am i missing something?)
seaweedfactory
PostPosted: Fri Dec 21, 2012 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dragon's Lair
PostPosted: Sat Dec 22, 2012 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
When you use the TL072 with a single supply, you create a "virtual" ground that is half of your supply voltage, so the op amp never actually goes to ground, try using an op amp that is designed for single supply use like the LM358 and see if that helps.
