CMOS Robotic Voice?! (Pseudo-Vocoder sceheme)
Page 1 of 1 [5 Posts]
VanaVara
PostPosted: Mon Mar 18, 2013 6:01 pm    Post subject: CMOS Robotic Voice?! (Pseudo-Vocoder sceheme)
Subject description: Help with stripboard!
Hello,
I have found a little scheme of some kind of filter which acts like a very primitive vocoder on this german site: http://www.floka.com/cmos/cmossounds.html
I was wondering if anyone could help me with a stripboard of this baby?
It looks like it's quite interesting super lo-fi thing to play with;)
Thank you in advance!
PostPosted: Mon Mar 18, 2013 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks like it isn't actually a vocoder. It is a linear amp to boost the mic, and then a switch that toggles that sound off and on at a fast rate. It will be something similar to speaking into a fan.
I have experimented with using a 4066 to toggle a sound source in a similar fashion. The switch is very audible.
I was able to minimize the switch noise by using a transistor instead, but the best thing to use would be a VCA.
JacobWatters.com
Psyingo
PostPosted: Tue Mar 19, 2013 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
if by robot you mean dalek, and if by dalek you mean ring mod, and if by ring mod you mean amplitude modulation and if by amplitude modulation you mean square wave amplitude modulation... then yes, this is a robotic voice. it will sound ok build it and find out... as for stipboard... sorry. try it on your own.
bubzy
Audio files: 64
PostPosted: Wed Mar 20, 2013 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
wouldn't it be easier to use a fet instead of the 4066?
_Richard_ Smile
diablojoy
PostPosted: Wed Mar 20, 2013 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
or even a vactrol might be nice
ask where the hell am I
as good an answer as any
