sepiakeys
Posted: Wed Mar 05, 2014 8:16 am Post subject:
Trigger modules with an analog gate-signal and audio-input? |
Hello!
I am running a Roland RS-09 through a Nord Micro Modular for effects processing.
Now, the RS-09 has a gate-output. So here is my question:
Is it ok to trigger an envelope-module in the Micro Modular with the gate-signal from the RS-09? In other words, will an analog gate signal do any harm to the A/D-convertrers in the Micro Modular?
If it is fine to do so, shall I run the signal from the audio-in-module directly into the gate-input of the envelpoe-module or is it better to put some logic- or audio-processing-module in the chain before the envelope-module?
Thanks to all Nord Modular Wizzards out there! |
Joined: Apr 03, 2004 Posts: 24509 Location: The Netherlands, Enschede
Posted: Wed Mar 05, 2014 2:58 pm Post subject:
I can not find what the gate level output for the rs-09 is .. but it may be a bit high to put in directly ... which could be solved by using two resistors.
Then the next thing is that the input of the micro modular is AC coupled, meaning you can not get a gate pulse in ... you will get an up going trigger on the rising gate edge and a down going trigger on the the other edge of the gate.
When a trigger is all you want, depending on if there is an additional inversion on the micro's input, you may have to invert the signal before using it - this can be done in the patch.
you can also reconstruct the gate signal by splitting the signal in a negative part and a positive part, then invert the negative path and the use the first pulse to set a flip-flop, and the second one to reset it. This can be done in the patch as well.
So .. you'd start by finding out the voltage levels for the rs-09 gate output.
When the rest seems like nuts-talk to you ... don't worry .. I can patch up some examples to get you through .. but first need to know the levels :-) _________________ Jan
Posted: Wed Mar 05, 2014 3:06 pm Post subject:
oh and sepiakeys _________________ Jan
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Wed Mar 05, 2014 5:06 pm Post subject:
Hi sepiakeys,
Somewhere in the NM1 Archive you can find my Pearl patches.
Like the Pearl Drum synth.
Audio-in is triggering gates. |
sepiakeys
Posted: Thu Mar 06, 2014 5:50 am Post subject:
The Roland RS-09 gate voltage is the following: off: 0V / on: +14V
I also had a try with audio triggering the envelope: routing the audio signal into a pulse module and then into the gate of the envelope worked quite well, as long als the pulse was set to have a certain length. |
Posted: Thu Mar 06, 2014 11:24 am Post subject:
14 Volt seems a bit much ... would reduce it by a factor of ten or so ... two resistors let's say 1k and 10k, like this:
| Code: |
Roland side -> NM side
10k
>---[____]---*------>
| | 1k
ground
The audio in that you use now, you could also use an envelope follower to extract the volume from the incoming audio, then compare that to some level and start the envelope from that. _________________ Jan
avantronica
Posted: Wed Aug 12, 2015 7:48 am Post subject:
| Blue Hell wrote: | 14 Volt seems a bit much ... would reduce it by a factor of ten or so ... two resistors let's say 1k and 10k, like this:
| Code: |
10k
| | 1k
ground
The audio in that you use now, you could also use an envelope follower to extract the volume from the incoming audio, then compare that to some level and start the envelope from that. |
Hey - Has anyone any opinions or links to relevant threads regarding the viability of using the Audio Inputs in a CV input capacity, this video was linked up on an unrelated Elektron thread and I'm not going to test it out for the reasons alluded to above -high voltages !
There is a patch posted at the end of the clip, but no word on the voltage ranges on gate or pitch (but pitch noodles seem within a volt or 2 max)
This is my first relevant thread found, I thought it wouldn't do any harm to tag this on here whilst I search for or create another. I have the G1key and Micro and I'm able to get +/3.5v from the headphones - just wondering what safe voltages I may be able to feed in and what implications there may be concerning the DC signals
Any thoughts or pointers welcome
edited for link > https://www.youtube.com/watch?v=piDmOAr8njc |
