Need some help LFO trimming (scope photos included)
Page 1 of 1 [4 Posts]
koenpepping
PostPosted: Fri Jul 25, 2014 7:01 am    Post subject: Need some help LFO trimming (scope photos included) Reply with quote  Mark this post and the followings unread
I am trying to trim my yusynth LFO, but it doesn't seem to work really well. (scope y is divided by 5v)
I've tried a lot but:
The LED is always on, it doesn't blink
The triangle looks more like a saw
Pulsewidth is varies from 0% to 10% (as you can see on the picture)
Sine doesn't really look like a sine (see picture)
what can i do?
thanks!
Saw
 Filesize:  600.81 KB
 Viewed:  561 Time(s)
Triangle
 Filesize:  751.63 KB
 Viewed:  450 Time(s)
Sine
 Filesize:  764.39 KB
 Viewed:  470 Time(s)
Pulse (on maximum pulsewidth, minimum is just a flat line)
 Filesize:  763.17 KB
 Viewed:  463 Time(s)
Andrej
PostPosted: Thu Aug 25, 2016 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi everyone.
I know this topic is old, but same problems remain. i've got the same trimming problems. and my LFO2 oscillates at very high frequency, just like VCO. I used ICM7555 , TL071 and TL074. all parts were checked before soldering and all voltages are ok.
any help please?
yusynth
PostPosted: Tue Sep 06, 2016 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you used a BC557 (PNP) for Q1 ?
For your scope shot what is the amplitude (V/square) and time scale (ms/square) ?
Yves
RyBowk
PostPosted: Mon Nov 18, 2019 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the exact same issues as this, does anyone know the solutions at all yet? I have replaced all ic’s, transistors, caps. No change. My scope images are exactly the same as these. I am powering at 12v by the way many thanks Ryan
