connect two hin hongs to the same keyboard controllor?
Page 1 of 1 [3 Posts]
brainstormer
PostPosted: Tue Aug 19, 2014 6:07 pm    Post subject: connect two hin hongs to the same keyboard controllor? Reply with quote  Mark this post and the followings unread
How is it possible to connect two hin hong keyboards to the same keyboard controller? The limitation of two notes and the small 3 octave keyboard should be overrided somehow.
Robert Pearson
http://www.paramind.net
http://www.telicalbooks.com
http://www.regenerativemusic.net
PostPosted: Wed Aug 20, 2014 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Check out this thread for the schematic. Since it's not a matrix based keyboard it could be as simple as
connecting one keyboard (the keys) to both keyboards but maybe you'd need some diodes to isolate them from eachother.
You could also run one keyboard at a lower clock speed which gives you a wider octave range instead of more voices.
brainstormer
PostPosted: Wed Aug 20, 2014 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. Isn't there a way to make all these toy keyboards into more of a modular system? At least for the oscillators? I know the main Yamaha PSS/PSR chip that was used on the early soundblaster has a lot of potential for more than sound generation. It seems the "oscilattors" with additional tone colors is what is needed, which more toy keyboards can provide.
Robert Pearson
