vst/piano roll problem
Page 1 of 1 [4 Posts]
Superdong
PostPosted: Fri Dec 12, 2014 3:31 pm    Post subject: vst/piano roll problem
Subject description: i dont own a actual synth
hi im a beginner and i use fl studio 10
in fl you kan use piano roll but how can i get a vst to piano roll
i can get any sound out of vsts
do i HAVE to have an actual physiacal synth or can i do it all in fl
thanks beforehand
PostPosted: Fri Dec 12, 2014 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am sorry but I do not know the answer to your question ... but welcome Superdong .. and a little word of order ... please do not double post, I have removed the other one.
Nickson
PostPosted: Fri Dec 26, 2014 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
First of all, please get a license for FL studio (it is in discount now).
To answer your question;
There are many ways, here are two of them:
1. You need to load the vst (add it), from there you right klick on the vst block/button and then you go to piano roll. Copy + Paste the midi information from where you have written the midi information.
2. Right klick on the block with the existing midi information, it will say 'replace instrument' or something like that. Select the vst you want to use and you are done.
It has been a while since i've used FL studio so the names might be a little different.
Hope this answered your question!
Nick,
PS: What kind of music do you make?
Nickson
PostPosted: Fri Dec 26, 2014 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
And no you do not need an actual hardware synth.
VST stands for Virtual Studio Technology
