okelk
Posted: Sun Mar 15, 2015 8:07 am Post subject:
Logarithmic resistor ladder |
Has anybody used a logarithmic resistor ladder instead of the standard r2r ladder before?
correct me if I'm wrong, but wouldn't a d/a converter with a logarithmic response make sense, especially for controlling simple VCOs (4046 and such..) that have a linear response (do they?).
Assuming the vco has a linear response it should be easy to get various equal tempered scales that way... |
Posted: Sun Mar 15, 2015 10:00 am Post subject:
You can get better range with less voltage range needed if your VCO core has a log response rather than a linear one. If your hypothetical D/A converter has a logarithmic voltage output, that actually limits the input range unless you have an enormous power supply.
That said, I can see applications where such a thing would be useful, but it's not as much general use.
What would be interesting would be a digital -> current converter that had a logarithmic response, that could drive a core directly without the same kind of limitation to fit inside the rails.... |
okelk
Posted: Mon Mar 16, 2015 2:31 am Post subject:
| elmegil wrote: |
interesting idea.
I guess this could be done with a fixed voltage reference and fixed, current limiting resistors resistors that get switched into the circuit by analogue switches or a demultiplexer.
kind of like a hard-wired sequencer...
At least I think this should work for oscillator cores that require a current source and not a current sink.
in that case one would need something like an inverting current mirror...(is that even a thing?) |
